1.35.12 error
Cramac1
1.35.12 error
Post by Cramac1 »
Change monitor - storage
add - Optional Encoder Parameters
i get error
Re: 1.35.12 error
So this is a multi-server setup and it is trying to tell the other server to restart it's processes but authenticating via auth_hash is failing.
The most common cause of this is the different servers having different timezones set.
Cramac1
Re: 1.35.12 error
Post by Cramac1 »
thx, the problem is gone
Cramac1
Re: 1.35.12 error
Post by Cramac1 »
and what is the reason for this event recording? before updates and adding movflags=faststart, it worked as expected, recording for an hour without interruptions
strange end time of current recording.
another problem with - Advanced search
there is a Kur server, I write a server in the field. As a result, it finds nothing. Also with the error level
Cramac1
Re: 1.35.12 error
Post by Cramac1 »
SQL-ERR dbFetchOne no result, statement was 'SELECT count(*) AS Total FROM Logs WHERE (TimeKey LIKE ? OR Component LIKE ? OR ServerId LIKE ? OR Pid LIKE ? OR Code LIKE ? OR Message LIKE ? OR File LIKE ? OR Line LIKE ?)'params: %Err%,%Err%,%Err%,%Err%,%Err%,%Err%,%Err%,%Err%
SQL-ERR dbFetchAll no result, statement was 'SELECT TimeKey, Component, ServerId, Pid, Code, Message, File, Line FROM `Logs` WHERE (TimeKey LIKE ? OR Component LIKE ? OR ServerId LIKE ? OR Pid LIKE ? OR Code LIKE ? OR Message LIKE ? OR File LIKE ? OR Line LIKE ?) ORDER BY TimeKey DESC LIMIT ?, ?'params: %e%,%e%,%e%,%e%,%e%,%e%,%e%,%e%,0,25
Cramac1
Re: 1.35.12 error
Post by Cramac1 »
Cramac1 wrote: Wed Nov 04, 2020 7:09 pm and what is the reason for this event recording? before updates and adding movflags=faststart, it worked as expected, recording for an hour without interruptions
in log
11/08/20 07:18:44.325250 zma_m2[849444].INF-zm_monitor.cpp/1527 [Dav_2_9B_1: 001 - Opening new event 252815, section start]
11/08/20 07:19:24.211384 zma_m2[849444].INF-zm_monitor.cpp/1304 [Dav_2_9B_1: 1000 - Analysing at 22.73 fps]
11/08/20 07:20:02.551998 zma_m2[849444].INF-zm_monitor.cpp/1304 [Dav_2_9B_1: 2000 - Analysing at 26.32 fps]
11/08/20 07:20:43.886770 zma_m2[849444].INF-zm_monitor.cpp/1304 [Dav_2_9B_1: 3000 - Analysing at 24.39 fps]
11/08/20 07:20:46.700587 zma_m2[849444].WAR-zm_monitor.cpp/1344 [Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size]
11/08/20 07:21:27.307232 zma_m2[849444].INF-zm_monitor.cpp/1304 [Dav_2_9B_1: 4000 - Analysing at 22.73 fps]
11/08/20 07:22:08.029281 zma_m2[849444].INF-zm_monitor.cpp/1304 [Dav_2_9B_1: 5000 - Analysing at 24.39 fps]
11/08/20 07:22:48.400080 zma_m2[849444].INF-zm_monitor.cpp/1304 [Dav_2_9B_1: 6000 - Analysing at 25.00 fps]
11/08/20 07:23:28.635962 zma_m2[849444].INF-zm_monitor.cpp/1304 [Dav_2_9B_1: 7000 - Analysing at 25.00 fps]
11/08/20 07:24:09.323984 zma_m2[849444].INF-zm_monitor.cpp/1304 [Dav_2_9B_1: 8000 - Analysing at 24.39 fps]
11/08/20 07:24:50.021434 zma_m2[849444].INF-zm_monitor.cpp/1304 [Dav_2_9B_1: 9000 - Analysing at 24.39 fps]
11/08/20 07:25:31.272423 zma_m2[849444].INF-zm_monitor.cpp/1304 [Dav_2_9B_1: 10000 - Analysing at 24.39 fps]
11/08/20 07:26:11.496523 zma_m2[849444].INF-zm_monitor.cpp/1304 [Dav_2_9B_1: 11000 - Analysing at 25.00 fps]
11/08/20 07:26:15.349779 zma_m2[849444].WAR-zm_monitor.cpp/1344 [Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size]
11/08/20 07:26:58.895855 zma_m2[849444].INF-zm_monitor.cpp/691 [Dav_2_9B_1: image_count:11554 - Closing event 252815, shutting down]
11/08/20 07:27:03.983295 zma_m2[849444].INF-zm_event.cpp/619 [Updating frames delta by 0.01 sec to match video file]
11/08/20 07:27:26.885458 zma_m2[850271].INF-zma.cpp/136 [In mode 4/1, warming up]
11/08/20 07:27:28.577435 zma_m2[850271].WAR-zm_monitor.cpp/889 [Impossible situation. No timestamp on captured image index was 0, image-buffer_count was (51)]
11/08/20 07:27:29.793552 zma_m2[850271].WAR-zm_monitor.cpp/889 [Impossible situation. No timestamp on captured image index was 0, image-buffer_count was (51)]
11/08/20 07:27:53.550289 zma_m2[850282].INF-zma.cpp/136 [In mode 4/1, warming up]
11/08/20 07:27:55.078607 zma_m2[850282].ERR-zm_monitor.cpp/914 [No diff between time_diff = 0.000000 (0:1604809673.246234 - 0:1604809673.246234), ibc: 51]
11/08/20 07:27:56.594358 zma_m2[850282].ERR-zm_monitor.cpp/914 [No diff between time_diff = 0.000000 (0:1604809673.246234 - 0:1604809673.246234), ibc: 51]
11/08/20 07:27:58.804986 zma_m2[850282].INF-zm_monitor.cpp/1527 [Dav_2_9B_1: 001 - Opening new event 252835, section start]
11/08/20 07:28:00.684807 zma_m2[850282].INF-zm_monitor.cpp/691 [Dav_2_9B_1: image_count:2 - Closing event 252835, shutting down]
11/08/20 07:28:02.518612 zma_m2[850282].INF-zm_event.cpp/619 [Updating frames delta by -0.04 sec to match video file]
11/08/20 07:28:24.835779 zma_m2[850355].INF-zma.cpp/136 [In mode 4/1, warming up]
11/08/20 07:28:28.096839 zma_m2[850355].INF-zm_monitor.cpp/1527 [Dav_2_9B_1: 001 - Opening new event 252837, section start]
11/08/20 07:28:33.965516 zma_m2[850355].INF-zm_monitor.cpp/691 [Dav_2_9B_1: image_count:2 - Closing event 252837, shutting down]
11/08/20 07:28:44.086944 zma_m2[850373].INF-zma.cpp/136 [In mode 4/1, warming up]
11/08/20 07:28:45.009150 zma_m2[850373].INF-zm_monitor.cpp/1527 [Dav_2_9B_1: 001 - Opening new event 252841, section start]
11/08/20 07:28:54.807551 zma_m2[850373].INF-zm_monitor.cpp/691 [Dav_2_9B_1: image_count:37 - Closing event 252841, shutting down]
11/08/20 07:28:55.644398 zma_m2[850373].INF-zm_event.cpp/619 [Updating frames delta by -1.93 sec to match video file]
Cramac1
Re: 1.35.12 error
Post by Cramac1 »
update to 1.35.13
search not work
QL-ERR dbFetchAll no result, statement was 'SELECT TimeKey, Component, ServerId, Pid, Code, Message, File, Line FROM `Logs` WHERE (Server LIKE ?) ORDER BY TimeKey DESC LIMIT ?, ?'params: kur,0,100 /usr/share/zoneminder/www/includes/database.php 194
2020-11-08 10:47:14 web_php Dav 881350 ERR SQL-ERR 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 'Server' in 'where clause'', statement was 'SELECT TimeKey, Component, ServerId, Pid, Code, Message, File, Line FROM `Logs` WHERE (Server LIKE ?) ORDER BY TimeKey DESC LIMIT ?, ?' params:kur,0,100 /usr/share/zoneminder/www/includes/database.php 161
2020-11-08 10:47:14 web_php Dav 881350 ERR SQL-ERR dbFetchOne no result, statement was 'SELECT count(*) AS Total FROM Logs WHERE (Server LIKE ?)'params: kur /usr/share/zoneminder/www/includes/database.php 170
2020-11-08 10:47:14 web_php Dav 881350 ERR SQL-ERR 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 'Server' in 'where clause'', statement was 'SELECT count(*) AS Total FROM Logs WHERE (Server LIKE ?)' params:kur /usr/share/zoneminder/www/includes/database.php 161
2020-11-08 10:47:14 web_php Dav 850956 ERR SQL-ERR dbFetchAll no result, statement was 'SELECT TimeKey, Component, ServerId, Pid, Code, Message, File, Line FROM `Logs` WHERE (Server LIKE ?) ORDER BY TimeKey DESC LIMIT ?, ?'params: kur,0,100 /usr/share/zoneminder/www/includes/database.php 194
2020-11-08 10:47:14 web_php Dav 850956 ERR SQL-ERR 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 'Server' in 'where clause'', statement was 'SELECT TimeKey, Component, ServerId, Pid, Code, Message, File, Line FROM `Logs` WHERE (Server LIKE ?) ORDER BY TimeKey DESC LIMIT ?, ?' params:kur,0,100
Cramac1
Re: 1.35.12 error
Post by Cramac1 »
update to 1.35.13, new server
zm not start capture
Memory map file '/dev/shm/zm.mmap.28' does not exist in zmMemAttach. zmc might not be running.
disabled debug in settings, restarted. Everything went back to work.
Cramac1
Re: 1.35.12 error
Post by Cramac1 »
once display events, ajax by timeout.
v1.35.13
