Installation error
Posted: Thu Nov 05, 2020 1:06 am
I followed the instructions to install zoneminder from: https://wiki.zoneminder.com/Debian_10_B ... om_ZM_Repo but I am greeted with the following error:
Is there anything I can do?
sudo apt install zoneminder
Reading package lists... Done
Building dependency tree
Reading state information... Done
zoneminder is already the newest version (1.34.22-buster1).
The following packages were automatically installed and are no longer required:
libmemcachedutil2 libmicrodns0 libva-wayland2 proftpd-doc rpi-eeprom-images
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 86 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up zoneminder (1.34.22-buster1) ...
Detected db service is mariadb.service
mysqladmin: connect to server at 'localhost' failed
error: 'Access denied for user 'root'@'localhost' (using password: NO)'
Creating zm db
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
Error creating db.
dpkg: error processing package zoneminder (--configure):
installed zoneminder package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
