camera shows vertical striped effect
Posted: Fri Nov 06, 2020 10:24 pm
Hi, 1st time post,long time user. I'm not even sure how to explain this. What is causing my camera to do this (attached)
https://imgbox.com/t1Phptrz
The top part of the image shows the forest. Go down about 10% of the image and the prior row of pixels is repeated until the bottom of the image, giving a vertical striped effect. Sometimes the majority of the picture is solid green. I'm monitoring property hundreds of miles away on a connection with 5 up. Could I be running out of bandwidth? The other 4 cameras don't have this issue.
thanks,
Steve
thanks,
Steve
