Hi!
There are several projects and services utilizing AWS and GCP platforms for facial and object recognition that you can leverage for your idea. Both AWS and GCP offer robust and scalable solutions for these purposes, which would be ideal for integrating with your Home Assistant setup without overburdening your Intel NUC.
AWS Services for Facial and Object Recognition
Amazon Rekognition:
Description: This is a powerful image and video analysis service that can identify objects, people, text, scenes, and activities. It also offers facial analysis and facial recognition capabilities.
How to Use: You can send your alarm.jpg files to Amazon Rekognition using their SDKs or APIs. The service will process the images and return metadata that you can then use in your Home Assistant setup.
Example: Amazon Rekognition Documentation
GCP Services for Facial and Object Recognition
Google Cloud Vision:
Description: This service provides powerful image analysis capabilities, including object detection, facial recognition, and text extraction.
How to Use: You can upload your images to Google Cloud Storage and use the Cloud Vision API to analyze them. The API will return detailed information about the objects and faces detected in the images.
Example: Google Cloud Vision Documentation
Steps to Integrate with Home Assistant
Upload and Analyze Images:
AWS Rekognition:
Upload your alarm.jpg file to an S3 bucket.
Use the Rekognition API to analyze the image.
Parse the response to extract the necessary information.
Upload your alarm.jpg file to Google Cloud Storage.
Use the Vision API to analyze the image.
Integrate with Home Assistant:
Use Home Assistant's RESTful API or MQTT to send the processed data from AWS or GCP to your Home Assistant instance.
Create automations or scripts in Home Assistant to act on the received data (e.g., send notifications, trigger alarms, etc.).
Example Projects and Resources
GitHub Repositories:
home-assistant-rekognition: A custom component for integrating Amazon Rekognition with Home Assistant.
cloud-vision-ha: A custom component for integrating Google Cloud Vision with Home Assistant.
Tutorials and Guides:
Integrating Amazon Rekognition with Home Assistant
Google Cloud Vision and Home Assistant Integration
By using these services, you can offload the heavy processing work to AWS or GCP, making your Home Assistant setup more efficient and scalable. If you need further assistance, the documentation and community forums for AWS, GCP, and Home Assistant are excellent resources.
Good luck with your project!
You can also check this article -
AWS Automation Tools For Disaster Recovery
