unable to connect to API V1.34.22
david1234
Post by david1234 »
I have a working zone-minder
record camera , see camera online on browser
but I can't login using API
when I run this command from the server itself I get "Not Found"
pi@raspberrypi:~$ curl -XPOST -d "user=David&pass=MyRealPassword!" http://10.0.0.105/zm/api/host/login.json
{"name":"Not Found","message":"Not Found","url":"\/api\/zm\/api\/host\/login.json"}
when I enter to 10.0.0.105/zm from the browser I get the login page
everything is OK
what it could be ?
what else can I check ?
I did everything it said it the manual
I had the same problem on version 1.32.X - so I upgrade
Please advise
Thanks ,
Bluemax
Re: unable to connect to API V1.34.22
Post by Bluemax »
Zoneminder on which distribution? It probably hasn't been set up properly by the maintainer. Usually it doesn't belong here but we will see how far we can get.
gbruneau
Post by gbruneau »
Make sure that OPT_USE_API is checked in the system options.
burger
Post by burger »
1. Install Zoneminder using officially recommended documentation (e.g. https://wiki.zoneminder.com/Debian or https://wiki.zoneminder.com/Ubuntu)
2. Follow API configuration on official zoneminder documentation (zoneminder.readthedocs.org)
3. curl -X POST -d "user=somename&pass=somepass" http://serverip/zm/api/host/getVersion.json (from https://wiki.zoneminder.com/API, but this is also in readthedocs as well)
At the moment, that is the proper way to setup API without any trouble. If you deviate from this (use FreeBSD, Docker, Alpine, etc)(follow instructions from your cousin's uncle's mother), you are on your own.
fastest way to test streams:
david1234
Post by david1234 »
I'm using Pi
I download pre-build image from here:
https://zmrepo.zoneminder.com/
have ty to reach the the pesrson how put it - no success
have try to go everything it said in the manual - still get the same "not found' answer
OPT_USE_API is enabled
reboot the pi and try again
I have try with and without a password
none of them work
is there any way to print all the setting ? so maybe someone will see and poin at the problem ?
Thanks,
Bluemax
Post by Bluemax »
Please post the Apache/site-specific zoneminder.conf.
david1234
Post by david1234 »
on the Pi I have the file here:
 /etc/apache2/sites-available/zoneminder.conf
is this the same?
this is the file:
<VirtualHost *:80>
  DocumentRoot    /usr/share/zoneminder/www
  ServerName      zm
  ErrorLog        /var/log/apache2/error.log
  Alias /zm/cache "/var/cache/zoneminder/cache"
  Alias /cache "/var/cache/zoneminder/cache"
  <Directory "/var/cache/zoneminder/cache">
    AllowOverride None
    <IfModule mod_authz_core.c>
       # Apache 2.4
       Require all granted
    </IfModule>
  </Directory>
  ScriptAlias /cgi-bin/ /usr/lib/zoneminder/cgi-bin/
  ScriptAlias /zm/cgi-bin/ /usr/lib/zoneminder/cgi-bin/
    AllowOverride None
    Require all granted
  </Directory>
    php_flag register_globals off
    Options +Indexes +FollowSymLinks
    AllowOverride All
    <IfModule mod_dir.c>
      DirectoryIndex index.php
    </IfModule>
    #Satisfy Any
    Order allow,deny
    Allow from all
  </Directory>
    AllowOverride All
    </IfModule>
    #Satisfy Any
    Order allow,deny
    Allow from all
  </Directory>
     RewriteEngine on
     RewriteBase /api
  </Directory>
   RewriteEngine on
   RewriteRule ^$ webroot/ [L]
   RewriteBase /api
  </Directory>
    RewriteEngine On
    RewriteRule ^ index.php [L]
    RewriteBase /api
  </Directory>
do you need anything else?
Thanks ,
Bluemax
Post by Bluemax »
Create a backup of the file and try this config.
https://github.com/ZoneMinder/zoneminde ... inder.conf
Reload the config or restart Apache.
david1234
Post by david1234 »
I notice I have 2 files with the name in 2 places
 /etc/apache2/sites-enabled/zoneminder.conf
I cahgne both of them to what you post
then I reload the apache service by
 sudo systemctl restart apache2.service
chek to see if the everything is working using the browser - I can log on and see the cameras
but still when I use the curl commnd
 curl -X POST -d "user=David&pass=david" http://10.0.0.105/zm/api/host/getVersion.json
I get the same error:
{"name":"Not Found","message":"Not Found","url":"\/api\/getVersion.json"}
nothing on
very strange no?
what else could it be ?
Thank you ,
Those Apache configs are the exact same file. Sites-enabled should be a symlink to the sites-available config file. So you just edit the real one.
Bluemax
Post by Bluemax »
The most 'API not found' errors are probably due to bad rewrite rules. The server is pointing to the wrong path.
There should be an 'access.log' near the 'error.log' that should log all accesses. It might show you where the requests are going. Compare that to the webservers real path/folder structure. You could also check the browser 'console' (Firefox=F12) for something useful.
david1234
Post by david1234 »
when I look at the files they are empty
and las modify when I install the image
 ls -lst /var/log/apache2/access*
0 -rw-r----- 1 root adm   0 Jun 17 00:00 /var/log/apache2/access.log
4 -rw-r----- 1 root adm 623 Apr 29  2020 /var/log/apache2/access.log.1
and when I look at the file
 cat /var/log/apache2/access.log.1
192.168.9.119 - - [29/Apr/2020:17:10:30 +0100] "GET / HTTP/1.1" 200 3382 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko
) Chrome/70.0.3538.77 Safari/537.36"
192.168.9.119 - - [29/Apr/2020:17:10:30 +0100] "GET /icons/openlogo-75.png HTTP/1.1" 200 6042 "http://192.168.9.104/" "Mozilla/5.0 (X11; Linux x86_
64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.77 Safari/537.36"
192.168.9.119 - - [29/Apr/2020:17:10:30 +0100] "GET /favicon.ico HTTP/1.1" 404 495 "http://192.168.9.104/" "Mozilla/5.0 (X11; Linux x86_64) AppleWe
which is even more strange becuse my home netwrok is 10.0.0.0/24 and not 192.168.9.0/24
Given those are months old, I’d assume Apache is not logging there. Do a find command and look for error and access and then hunt/grep through the results.
The .htaccess files are something that has caused me problems in the past.
david1234
Post by david1234 »
I found this
 ls -lstra /var/log/apache2/other_vhosts_access.log
4 -rw-r----- 1 root adm 113 Nov 29 11:18 /var/log/apache2/other_vhosts_access.log
pi@raspberrypi:~$ ls -lstra /var/log/apache2/other_vhosts_access*
 4 -rw-r----- 1 root adm   781 Oct 20 20:45 /var/log/apache2/other_vhosts_access.log.14.gz
12 -rw-r----- 1 root adm 11681 Oct 21 17:59 /var/log/apache2/other_vhosts_access.log.13.gz
 4 -rw-r----- 1 root adm  3022 Oct 29 17:30 /var/log/apache2/other_vhosts_access.log.12.gz
 4 -rw-r----- 1 root adm   733 Oct 30 09:49 /var/log/apache2/other_vhosts_access.log.11.gz
 4 -rw-r----- 1 root adm  2579 Nov  1 19:24 /var/log/apache2/other_vhosts_access.log.10.gz
 4 -rw-r----- 1 root adm   344 Nov  3 17:07 /var/log/apache2/other_vhosts_access.log.9.gz
 4 -rw-r----- 1 root adm  3152 Nov  4 17:08 /var/log/apache2/other_vhosts_access.log.8.gz
 4 -rw-r----- 1 root adm  3493 Nov  5 18:17 /var/log/apache2/other_vhosts_access.log.7.gz
 4 -rw-r----- 1 root adm  3155 Nov  8 16:31 /var/log/apache2/other_vhosts_access.log.6.gz
 4 -rw-r----- 1 root adm  1822 Nov 10 17:58 /var/log/apache2/other_vhosts_access.log.5.gz
 4 -rw-r----- 1 root adm  1979 Nov 17 17:06 /var/log/apache2/other_vhosts_access.log.4.gz
 4 -rw-r----- 1 root adm  3149 Nov 18 17:26 /var/log/apache2/other_vhosts_access.log.3.gz
 8 -rw-r----- 1 root adm  5486 Nov 25 16:20 /var/log/apache2/other_vhosts_access.log.2.gz
28 -rw-r----- 1 root adm 26917 Nov 26 17:26 /var/log/apache2/other_vhosts_access.log.1
then I run the curl command
curl -X POST -d "user=David&pass=DavidPass" http://10.0.0.105/zm/api/host/getVersion.json
and saw a new file with today time stamp
 4 -rw-r----- 1 root adm   113 Nov 29 11:20 /var/log/apache2/other_vhosts_access.log
this is thew content of the file
pi@raspberrypi:~$ cat /var/log/apache2/other_vhosts_access.log
zm:80 10.0.0.105 - - [29/Nov/2020:11:20:47 +0200] "POST /zm/api/host/getVersion.json HTTP/1.1" 404 252 "-" "curl/7.64.0
404 - not found , the same as the api response
what now can I do \ search ?
Thanks ,
Can you test with authentication off?
Please check the filesystem where it's hosted to ensure it's free of .htaccess files. That's all the way from /usr/share/zoneminder/www/ to /usr/share/zoneminder/www/api/app/webroot/
Browse to http://10.0.0.105/zm/api and see if you see Cake errors.
