zmeventnotification installation problem
titof2375
Post by titof2375 »
Hello
here I am installing zoneminder 1.35 and especially zmeventnotification, I am following this tutorial in French.
https://www.nextdom.org/forum/projets-d ... c-nextdom/
and when i type this command
sudo -u www-data ./zmeventnotification.pl --config ./zmeventnotification.ini I end up with this error
Do you have a solution?
Re: zmeventnotification installation problem
Sort out the secrets.ini file. Might just be permissions if it exists.
titof2375
Post by titof2375 »
titof2375
Post by titof2375 »
Magic919 wrote: Tue Dec 29, 2020 7:21 am Sort out the secrets.ini file. Might just be permissions if it exists.
what do you mean
It clearly states that it encountered errors whilst reading the file.
titof2375
Post by titof2375 »
yes, is how to fix this problem, i don't understand how to do it
Understood.
Do
ls -la /etc/zm/secrets.ini
Hopefully the file IS there. If not, you need to create one.
I expect it’s there but not owned by www-data.
chown www-data:www-data /etc/zm/secrets.ini
That will change it to the web owner and should remove the error.
titof2375
Post by titof2375 »
thank you
