Noob needs some guidance
Posted: Thu Dec 31, 2020 3:22 am
I'm the "IT guy" at a business that has 16 analog cameras going into a SpyClops system. The owners of the business want remote access to the cameras bad and SpyClops works like 20% of the time. For the record I had no input at all when the system was installed.
So now I've been tasked to this fix this dumpster fire. At first I was going to get PCI capture cards, but after searching the forums it appears there are analog to IP video converters. I'm an electrical engineer by profession and am doing this as a favor to the business owner, so I am technically proficient, but I need to get up to speed on the camera stuff. I can build a computer to run the OS and software no problem, I just have to get the analog signals from all these cameras into the box. My questions are as follows...
#1 I have no idea what type of cameras the business has. They all come into the SpyClops system through BNC cables. Do I need to investigate to find out exactly what type of cameras they have before moving forward? SD, HD, does it matter?
#2 What type of video encoding will ZoneMinder accept? Is it standardized? There are many different video encoding standards. I would assume the output of the IP encoder could be important i.e. H.264 and all the other video formats I can't remember right now.
#3 What IP encoders would you recommend?
Thanks so much for the help, I'm doggy paddling so far.
