Have my options > e-mail, set as follow:
opt_email: checked
email_subject: ZoneMinder: Alarm - %MN% - %EI%
email_body:
An alarm has been detected at xyz Dr.
The details are as follows :-
Monitor : %MN%
Time : %ET%
e-mails are been generated with the default subject: ZoneMinder: Alarm - Door-3356 (51 - 29 44)
and
No changes in body:
An alarm has been detected on your installation of the ZoneMinder.
Monitor : Door
Event Id : 3356
Length : 14.02
Frames : 71 (44)
Scores : t1300 m51 a29
Any ideas?
e-mails events notification: wrong subject and body
Re: e-mails events notification: wrong subject and body
Had just rebooted to test if that would "fix" and finished phpmyadmin install to pick inside the DB and saw e-mails are now coming with the right config:
An alarm has been detected at XYZ Dr.
Monitor : Door
Time : 2021-01-27 17:46:10
Event Id : 3459
Length : 9.40
Frames : 45 (6)
Scores : t97 m25 a16
Issue closed.
Just don't know why it took a reboot ...
Monitor : Door
Event Id : 3459
Length : 9.40
Frames : 45 (6)
Issue closed.
Typically a reboot isn't required in gnu linux world. That's a windows thing. Usually restarting mariadb is enough.
For reference, email docs are here:
https://wiki.zoneminder.com/Email
https://wiki.zoneminder.com/How_to_get_ ... Zoneminder
Try to enclose your email text in code boxes next time to make it easier to read.
fastest way to test streams:
