Unable to send some Emails
stevewrightnz1
Post by stevewrightnz1 »
Hi guy's
Getting lots of these in my log.
2021-02-07 15:16:21	zmfilter_3		2650	ERR	Unable to send email: Net::CMD (Net::SMTP) DATAEND command failed.Last server message was:5.3.4 Error: message file too bigThis probably represents a problem with newline encoding at /usr/bin/zmfilter.pl line 856.	zmfilter.pl
Sending through Postfix on localhost.
Sending manually through Postfix from the CLI works fine.
The message on the Email Tab is :-
    An alarm has been detected on your installation of the ZoneMinder.
      The details are as follows :-
      Monitor  : %MN%
      Event Id : %EI%
      Length   : %EL%
      Frames   : %EF% (%EFA%)
      Scores   : t%EST% m%ESM% a%ESA%
      This alarm was matched by the %FN% filter and can be viewed at %EPS%
%EI1%
      ZoneMinder
Any ideas on how to fix this?
Steve
bkjaya1952
Re: Unable to send some Emails
Post by bkjaya1952 »
