Page 1 of 1
Cannot use "8 hour" or view "all events"
Posted: Tue Feb 09, 2021 6:25 pm
by frozenfood
ZM has been working OK for me for the past 3 weeks, but now I cannot view the "8 hour" or "all events" as the website crashes. it is possible to view 1 hr at a time by changing the time text to no more than 1-2 hours but anything more than that, it crashes. is it running out of memory? I have 16GB in the server
- Capture.JPG (120.91 KiB) Viewed 2615 times
Re: Cannot use "8 hour" or view "all events"
Posted: Wed Feb 10, 2021 1:47 am
by dougmccrary
Have you seen the bit about setting buffers to 2?
Posted: Wed Feb 10, 2021 5:43 am
by frozenfood
what buffers are you refering to?
It has worked this morning looking at 8 hours of night, so I can only conclude it is the large ammount of trigger events causing the fault.
Posted: Wed Feb 10, 2021 7:40 am
by dougmccrary
Posted: Wed Feb 10, 2021 4:57 pm
by frozenfood
- whatbuffers..JPG (58.69 KiB) Viewed 2525 times
i'm not sure what buffer you are refering to, so I set the only thing with buffer in the text to "2" and it still does not work
now clicking on "8 hours" lead to a white website with no infomation what so ever. is there any other settings that require adjustment?
Posted: Thu Feb 11, 2021 2:06 am
by dougmccrary
Dunno.
Quite a few problems with this build - but there's a newer one out today you should try.
Or go back to a release (1.34.x) version.
Posted: Thu Feb 11, 2021 5:41 am
by frozenfood
is there a reliable release? or should I just go back to shinobi?
I'm finding loads of other things that dont work, like the "download video" to a 1hr time it says it will be 4.6GB, doesnt ask me which stream it is going to download and then gives me a 450MB download, which is only 1 stream and only a fraction of the video, and it doesnt have the timestamp added, which makes the whole thing worthless if I wanted to get a video that wasnt picked up on a event, that was the prime reason I went to mocord.
Posted: Thu Feb 11, 2021 5:43 am
by Magic919
Stick to 1.34 releases. This is the development branch.
