From zmeventnotification.log
02/08/21 06:41:38.410982 zmeventnotification[15521].INF [main:991] [PARENT: using config file: /etc/zm/zmeventnotification.ini]
02/08/21 06:41:38.418643 zmeventnotification[15521].INF [main:991] [PARENT: using secrets file: /etc/zm/secrets.ini]
02/08/21 06:41:38.561990 zmeventnotification[15521].INF [main:991] [PARENT: Push enabled via FCM]
02/08/21 06:41:38.563705 zmeventnotification[15521].INF [main:991] [PARENT: MQTT Disabled]
02/08/21 06:41:38.565444 zmeventnotification[15521].INF [main:991] [PARENT: |------- Starting ES version: 6.1.11 ---------|]
02/08/21 06:41:38.665532 zmeventnotification[15521].INF [main:991] [PARENT: Event Notification daemon v 6.1.11 starting]
02/08/21 06:41:38.667449 zmeventnotification[15521].INF [main:991] [PARENT: Re-loading monitors]
02/08/21 06:41:38.795061 zmeventnotification[15521].INF [main:991] [PARENT: Secure WS(WSS) is enabled...]
02/08/21 06:41:38.797052 zmeventnotification[15521].INF [main:991] [PARENT: Web Socket Event Server listening on port 9000]
02/08/21 06:46:43.799504 zmeventnotification[15521].INF [main:991] [PARENT: Re-loading monitors]
02/08/21 06:51:48.803583 zmeventnotification[15521].INF [main:991] [PARENT: Re-loading monitors]
02/08/21 06:56:53.804341 zmeventnotification[15521].INF [main:991] [PARENT: Re-loading monitors]
02/08/21 07:00:38.803182 zmeventnotification[15521].INF [main:991] [PARENT: New event 331 reported for Monitor:2 (Name:DrivewayHD) Linked[last process
ed eid:]]
02/08/21 07:01:58.804152 zmeventnotification[15521].INF [main:991] [PARENT: Re-loading monitors]
02/08/21 07:04:28.803667 zmeventnotification[15521].INF [main:991] [PARENT: New event 333 reported for Monitor:2 (Name:DrivewayHD) Linked[last process
ed eid:331]]
02/08/21 07:05:08.228809 zmeventnotification[15600].INF [main:991] [|----> FORK:DrivewayHD (2), eid:331 Event 331 for Monitor 2 has finished]
02/08/21 07:05:12.232707 zmeventnotification[15600].INF [main:991] [|----> FORK:DrivewayHD (2), eid:331 end hooks/use hooks not being used, going to d
irectly send out a notification if checks pass]
02/08/21 07:05:14.235559 zmeventnotification[15600].INF [main:991] [|----> FORK:DrivewayHD (2), eid:331 Not sending event end alarm, as we did not sen
d a start alarm for this, or start hook processing failed]
02/08/21 07:07:03.803686 zmeventnotification[15521].INF [main:991] [PARENT: Re-loading monitors]
02/08/21 07:08:51.276894 zmeventnotification[15629].INF [main:991] [|----> FORK:DrivewayHD (2), eid:333 Event 333 for Monitor 2 has finished]
02/08/21 07:08:55.280320 zmeventnotification[15629].INF [main:991] [|----> FORK:DrivewayHD (2), eid:333 end hooks/use hooks not being used, going to d
02/08/21 07:08:57.282961 zmeventnotification[15629].INF [main:991] [|----> FORK:DrivewayHD (2), eid:333 Not sending event end alarm, as we did not sen
02/08/21 07:12:08.835555 zmeventnotification[15521].INF [main:991] [PARENT: Re-loading monitors]
02/08/21 07:17:13.803895 zmeventnotification[15521].INF [main:991] [PARENT: Re-loading monitors]
SKIPPING TO MOTION!!!!
02/09/21 17:14:22.791273 zmeventnotification[1139].INF [main:991] [PARENT: New event 563 reported for Monitor:2 (Name:DrivewayHD) Linked[last processe
d eid:558]]
02/09/21 17:14:57.791338 zmeventnotification[1139].INF [main:991] [PARENT: New event 564 reported for Monitor:1 (Name:DrivewaySD) Motion All[last proc
essed eid:557]]
02/09/21 17:14:57.793548 zmeventnotification[1139].INF [main:991] [PARENT: New event 565 reported for Monitor:2 (Name:DrivewayHD) Linked[last processe
d eid:563]]
02/09/21 17:15:37.791765 zmeventnotification[1139].INF [main:991] [PARENT: Re-loading monitors]
02/09/21 17:18:45.963673 zmeventnotification[12382].INF [main:991] [|----> FORK:DrivewayHD (2), eid:563 Event 563 for Monitor 2 has finished]
02/09/21 17:18:47.966960 zmeventnotification[12382].INF [main:991] [|----> FORK:DrivewayHD (2), eid:563 Not sending over FCM as notify filters are on_
success:all and on_fail:none]
02/09/21 17:18:49.969500 zmeventnotification[12382].INF [main:991] [|----> FORK:DrivewayHD (2), eid:563 end hooks/use hooks not being used, going to d
02/09/21 17:18:51.971562 zmeventnotification[12382].INF [main:991] [|----> FORK:DrivewayHD (2), eid:563 Not sending event end alarm, as we did not sen
02/09/21 17:19:20.800915 zmeventnotification[12403].INF [main:991] [|----> FORK:DrivewayHD (2), eid:565 Event 565 for Monitor 2 has finished]
02/09/21 17:19:20.800952 zmeventnotification[12402].INF [main:991] [|----> FORK:DrivewaySD (1), eid:564 Event 564 for Monitor 1 has finished]
02/09/21 17:19:22.804134 zmeventnotification[12402].INF [main:991] [|----> FORK:DrivewaySD (1), eid:564 Not sending over FCM as notify filters are on_
02/09/21 17:19:22.804134 zmeventnotification[12403].INF [main:991] [|----> FORK:DrivewayHD (2), eid:565 Not sending over FCM as notify filters are on_
02/09/21 17:19:24.844542 zmeventnotification[12403].INF [main:991] [|----> FORK:DrivewayHD (2), eid:565 end hooks/use hooks not being used, going to d
02/09/21 17:19:24.844542 zmeventnotification[12402].INF [main:991] [|----> FORK:DrivewaySD (1), eid:564 end hooks/use hooks not being used, going to d
02/09/21 17:19:26.849269 zmeventnotification[12402].INF [main:991] [|----> FORK:DrivewaySD (1), eid:564 Not sending event end alarm, as we did not sen
02/09/21 17:19:26.849269 zmeventnotification[12403].INF [main:991] [|----> FORK:DrivewayHD (2), eid:565 Not sending event end alarm, as we did not sen
02/09/21 17:20:42.791466 zmeventnotification[1139].INF [main:991] [PARENT: Re-loading monitors]
zmesdetect_m1.log
02/08/21 17:05:22 zmesdetect_m1[18246] INF ZMLog.py:219 [Setting up signal handler for logs]
02/08/21 17:05:22 zmesdetect_m1[18246] INF zm_detect.py:273 [---------| app:6.1.11, pyzm:0.3.32, ES:6.1.11 , OpenCV:4.5.1|------------]
02/08/21 17:05:22 zmesdetect_m1[18246] INF zm_detect.py:298 [Importing local classes for Object/Face]
02/08/21 17:05:23 zmesdetect_m1[18246] INF zm_detect.py:321 [Connecting with ZM APIs]
02/08/21 17:39:34 zmesdetect_m1[18513] INF ZMLog.py:219 [Setting up signal handler for logs]
02/08/21 17:39:34 zmesdetect_m1[18513] INF zm_detect.py:273 [---------| app:6.1.11, pyzm:0.3.32, ES:6.1.11 , OpenCV:4.5.1|------------]
02/08/21 17:39:34 zmesdetect_m1[18513] INF zm_detect.py:298 [Importing local classes for Object/Face]
02/08/21 17:39:34 zmesdetect_m1[18513] INF zm_detect.py:321 [Connecting with ZM APIs]
02/08/21 18:06:09 zmesdetect_m1[18622] INF ZMLog.py:219 [Setting up signal handler for logs]
02/08/21 18:06:09 zmesdetect_m1[18622] INF zm_detect.py:273 [---------| app:6.1.11, pyzm:0.3.32, ES:6.1.11 , OpenCV:4.5.1|------------]
02/08/21 18:06:09 zmesdetect_m1[18622] INF zm_detect.py:298 [Importing local classes for Object/Face]
02/08/21 18:06:10 zmesdetect_m1[18622] INF zm_detect.py:321 [Connecting with ZM APIs]
02/08/21 21:12:27 zmesdetect_m1[19594] INF ZMLog.py:219 [Setting up signal handler for logs]
02/08/21 21:12:27 zmesdetect_m1[19604] INF ZMLog.py:219 [Setting up signal handler for logs]
02/08/21 21:12:28 zmesdetect_m1[19604] INF zm_detect.py:273 [---------| app:6.1.11, pyzm:0.3.32, ES:6.1.11 , OpenCV:4.5.1|------------]
02/08/21 21:12:28 zmesdetect_m1[19594] INF zm_detect.py:273 [---------| app:6.1.11, pyzm:0.3.32, ES:6.1.11 , OpenCV:4.5.1|------------]
02/08/21 21:12:28 zmesdetect_m1[19604] INF zm_detect.py:298 [Importing local classes for Object/Face]
02/08/21 21:12:28 zmesdetect_m1[19594] INF zm_detect.py:298 [Importing local classes for Object/Face]
02/08/21 21:12:29 zmesdetect_m1[19604] INF zm_detect.py:321 [Connecting with ZM APIs]
02/08/21 21:12:29 zmesdetect_m1[19594] INF zm_detect.py:321 [Connecting with ZM APIs]
02/08/21 21:13:26 zmesdetect_m1[19594] INF ZMLog.py:239 [Got interrupt, exiting]
02/08/21 22:00:18 zmesdetect_m1[1504] INF ZMLog.py:219 [Setting up signal handler for logs]
02/08/21 22:00:18 zmesdetect_m1[1504] INF zm_detect.py:273 [---------| app:6.1.11, pyzm:0.3.32, ES:6.1.11 , OpenCV:4.5.1|------------]
02/08/21 22:00:18 zmesdetect_m1[1504] INF zm_detect.py:298 [Importing local classes for Object/Face]
02/08/21 22:00:18 zmesdetect_m1[1504] INF zm_detect.py:321 [Connecting with ZM APIs]
02/09/21 06:18:56 zmesdetect_m1[6144] INF ZMLog.py:219 [Setting up signal handler for logs]
02/09/21 06:18:56 zmesdetect_m1[6144] INF zm_detect.py:273 [---------| app:6.1.11, pyzm:0.3.32, ES:6.1.11 , OpenCV:4.5.1|------------]
02/09/21 06:18:56 zmesdetect_m1[6144] INF zm_detect.py:298 [Importing local classes for Object/Face]
02/09/21 06:18:57 zmesdetect_m1[6144] INF zm_detect.py:321 [Connecting with ZM APIs]
02/09/21 16:26:09 zmesdetect_m1[11892] INF ZMLog.py:219 [Setting up signal handler for logs]
02/09/21 16:26:10 zmesdetect_m1[11892] INF zm_detect.py:273 [---------| app:6.1.11, pyzm:0.3.32, ES:6.1.11 , OpenCV:4.5.1|------------]
02/09/21 16:26:11 zmesdetect_m1[11892] INF zm_detect.py:298 [Importing local classes for Object/Face]
02/09/21 16:26:12 zmesdetect_m1[11892] INF zm_detect.py:321 [Connecting with ZM APIs]
02/09/21 17:14:58 zmesdetect_m1[12409] INF ZMLog.py:219 [Setting up signal handler for logs]
02/09/21 17:14:58 zmesdetect_m1[12409] INF zm_detect.py:273 [---------| app:6.1.11, pyzm:0.3.32, ES:6.1.11 , OpenCV:4.5.1|------------]
02/09/21 17:14:58 zmesdetect_m1[12409] INF zm_detect.py:298 [Importing local classes for Object/Face]
02/09/21 17:14:58 zmesdetect_m1[12409] INF zm_detect.py:321 [Connecting with ZM APIs]
zmNinja version:1.6.004 (android)
ZoneMinder version:1.34.23
Attachments area
Feb 8, 2021 09:25:53:321 PM DEBUG Modal is closed, so toggling or exiting
Feb 8, 2021 09:25:53:892 PM DEBUG Modal is closed, so toggling or exiting
Feb 8, 2021 09:25:56:567 PM INFO ******* app .run device ready
Feb 8, 2021 09:25:56:570 PM INFO Device is ready
Feb 8, 2021 09:25:56:570 PM INFO setting size
Feb 8, 2021 09:25:56:571 PM DEBUG UA is mozilla/5.0 (linux; android 11; sm-g986u1 build/rp1a.200720.012; wv) applewebkit/537.36 (khtml, like gecko) version/4.0 chrome/88.0.4324.152 mobile safari/537.36
Feb 8, 2021 09:25:56:571 PM INFO You are running on android
Feb 8, 2021 09:25:56:572 PM DEBUG Inside configureStorageDB
Feb 8, 2021 09:25:56:572 PM DEBUG configureStorageDB: trying order:["asyncStorage","localStorageWrapper"]
Feb 8, 2021 09:25:56:595 PM INFO configureStorageDB:localforage driver for storage:asyncStorage
Feb 8, 2021 09:25:56:596 PM DEBUG configureStorageDB:Making sure this storage driver works...
Feb 8, 2021 09:25:56:605 PM DEBUG resize/orient: 412(w) * 839(h)
Feb 8, 2021 09:25:56:622 PM DEBUG configureStorageDB:test get/set worked, this driver is ok...
Feb 8, 2021 09:25:56:624 PM INFO localforage driver:asyncStorage
Feb 8, 2021 09:25:56:625 PM INFO CloudSync: Syncing with cloud if enabled...
Feb 8, 2021 09:25:56:627 PM INFO user profile encrypted, decoding...
Feb 8, 2021 09:25:56:649 PM DEBUG deobfuscate: before:4040 after:16668 scheme:lzs
Feb 8, 2021 09:25:56:651 PM INFO Cloud sync is disabled, exiting...
Feb 8, 2021 09:25:56:652 PM INFO Cloudsync operation complete, continuing...
Feb 8, 2021 09:25:56:654 PM INFO >>>>No data to import....
Feb 8, 2021 09:25:56:655 PM INFO Updating statusbar
Feb 8, 2021 09:25:56:668 PM INFO Retrieving language before init is called...
Feb 8, 2021 09:25:56:672 PM INFO App Version: 1.6.004
Feb 8, 2021 09:25:56:673 PM INFO No language set, switching to en
Feb 8, 2021 09:25:56:675 PM INFO Device Language is:en
Feb 8, 2021 09:25:56:676 PM INFO >>>>Language to be used:en
Feb 8, 2021 09:25:56:678 PM DEBUG isFirstUse returned: false
Feb 8, 2021 09:25:56:679 PM DEBUG last state=app.log param=[object Object]
Feb 8, 2021 09:25:56:679 PM INFO Language file loaded, continuing with rest
Feb 8, 2021 09:25:56:680 PM INFO ZMData init: checking for stored variables & setting up log file
Feb 8, 2021 09:25:56:684 PM INFO Checking for new version updates...
Feb 8, 2021 09:25:56:740 PM INFO Setting up pause and resume handler AFTER language is loaded...
Feb 8, 2021 09:25:56:740 PM DEBUG Android detected, using cordova-multiwindow plugin for onStop/onStart instead
Feb 8, 2021 09:25:56:748 PM INFO user profile encrypted, decoding...
Feb 8, 2021 09:25:56:767 PM DEBUG deobfuscate: before:4040 after:16668 scheme:lzs
Feb 8, 2021 09:25:56:775 PM INFO Setting NVR init bandwidth to: highbw
Feb 8, 2021 09:25:56:775 PM INFO NVR init retrieved store loginData, marking init as complete
Feb 8, 2021 09:25:56:776 PM DEBUG Setting cordova header X-ZmNinja to zmNinja_1.6.004
Feb 8, 2021 09:25:56:777 PM INFO >>>> Disabling strict SSL checking (turn off in Dev Options if you can't connect)
Feb 8, 2021 09:25:56:780 PM INFO >>> Android: enabling inline image view for self signed certs
Feb 8, 2021 09:25:56:782 PM INFO Inside init-complete in app.js: All init over, going to portal login
Feb 8, 2021 09:25:56:786 PM DEBUG --> SSL is permissive, will allow any certs. Use at your own risk.
Feb 8, 2021 09:25:56:819 PM INFO Entering Portal Main
Feb 8, 2021 09:25:56:899 PM DEBUG Inside Portal login Enter handler
Feb 8, 2021 09:25:56:899 PM INFO User credentials are provided
Feb 8, 2021 09:25:56:900 PM INFO not checking for touchID
Feb 8, 2021 09:25:56:900 PM DEBUG unlock called with check PIN=true
Feb 8, 2021 09:25:56:900 PM DEBUG PIN code entered is correct, or there is no PIN set
Feb 8, 2021 09:25:56:901 PM INFO Cancelling zmAutologin timer
Feb 8, 2021 09:25:56:902 PM DEBUG ------> Not starting login timer for token. We will start a one time timer when we know how soon the access token will live
Feb 8, 2021 09:25:56:902 PM DEBUG Inside _doLogin()
Feb 8, 2021 09:25:56:903 PM DEBUG No need for re-captcha checks with tokens
Feb 8, 2021 09:25:56:903 PM DEBUG Resetting zmCookie...
Feb 8, 2021 09:25:56:904 PM INFO Detected token login supported
Feb 8, 2021 09:25:56:908 PM INFO Access token still has 106 minutes left, using it
Feb 8, 2021 09:25:56:909 PM INFO ----> Setting token re-login after 6360 seconds
Feb 8, 2021 09:25:56:914 PM DEBUG auth-success broadcast:Successful
Feb 8, 2021 09:25:56:923 PM DEBUG _doLogoutAndLogin: Clearing cookies
Feb 8, 2021 09:25:56:924 PM INFO Adding to chain stack: MYURL.duckdns.org/zm>https://MYURLHERE.duckdns.org/zm
Feb 8, 2021 09:25:56:924 PM INFO Fallback of MYURLHERE.duckdns.org/zm is
Feb 8, 2021 09:25:56:925 PM INFO reached end of chain loop
Feb 8, 2021 09:25:56:925 PM INFO No need to do a reachability test, as there are no fallbacks
Feb 8, 2021 09:25:56:932 PM INFO No need for logout!
Feb 8, 2021 09:25:56:933 PM DEBUG Inside _doLogin()
Feb 8, 2021 09:25:56:934 PM DEBUG No need for re-captcha checks with tokens
Feb 8, 2021 09:25:56:934 PM DEBUG Resetting zmCookie...
Feb 8, 2021 09:25:56:934 PM INFO Detected token login supported
Feb 8, 2021 09:25:56:935 PM INFO Access token still has 106 minutes left, using it
Feb 8, 2021 09:25:56:936 PM INFO ----> Setting token re-login after 6360 seconds
Feb 8, 2021 09:25:56:938 PM DEBUG auth-success broadcast:Successful
Feb 8, 2021 09:25:56:941 PM DEBUG PortalLogin: auth success
Feb 8, 2021 09:25:56:942 PM DEBUG getAPIversion called with https://MYURLHERE.duckdns.org/zm/api/host/getVersion.json?&token=<removed>
Feb 8, 2021 09:25:56:967 PM DEBUG CACHE: found for key: cached_api_version with expiry of:86400s
Feb 8, 2021 09:25:56:970 PM DEBUG CACHE: cached value for key:cached_api_version is good as 624 <86400
Feb 8, 2021 09:25:56:971 PM DEBUG snapshot supported in image.php
Feb 8, 2021 09:25:57:005 PM DEBUG obfuscate: original:16668 obfuscated:4040 scheme:lzs
Feb 8, 2021 09:25:57:007 PM DEBUG Setting server version to:1.34.23
Feb 8, 2021 09:25:57:008 PM DEBUG getAPI version succeeded with 1.34.23
Feb 8, 2021 09:25:57:012 PM INFO Got API version: 1.34.23
Feb 8, 2021 09:25:57:013 PM INFO First invocation of TimeZone, asking server
Feb 8, 2021 09:25:57:014 PM INFO EventSever: Initializing Websocket with URL wss://MYURLHERE.duckdns.org:9000
Feb 8, 2021 09:25:57:014 PM DEBUG EventSever: Using native websockets...
Feb 8, 2021 09:25:57:015 PM DEBUG Calling pushInit()
Feb 8, 2021 09:25:57:015 PM INFO EventSever: Setting up push registration
Feb 8, 2021 09:25:57:031 PM DEBUG Transitioning state to: app.log with param {}
Feb 8, 2021 09:25:57:035 PM DEBUG push: got token:eBKnTRKyRS-ZEE_TOKEN_OF_DOOOOOM_HERE
Feb 8, 2021 09:25:57:036 PM DEBUG push: setting up onMessageReceived...
Feb 8, 2021 09:25:57:040 PM DEBUG push: permissions are already enabled
Feb 8, 2021 09:25:57:040 PM DEBUG push: Channel created: zmninja
Feb 8, 2021 09:25:57:075 PM DEBUG EventSever: WebSocket open called with:{"webSocketId":"ABC123","code":101}
Feb 8, 2021 09:25:57:076 PM INFO EventSever: openHandshake: Websocket open, sending Auth
Feb 8, 2021 09:25:57:077 PM DEBUG EventSever: sendMessage: received->{"event":"auth","data":{"user":"MYUSER",<password removed>,"monlist":"1,2","intlist":"0,0","appversion":"1.6.004"},"token":"eBKnTRKyRS-ZEE_TOKEN_OF_DOOOOOM"}
Feb 8, 2021 09:25:57:077 PM DEBUG EventServer: ok to send message
Feb 8, 2021 09:25:57:080 PM DEBUG EventSever: openHandShake: state of push is enabled
Feb 8, 2021 09:25:57:080 PM DEBUG EventSever: sendMessage: received->{"event":"push","data":{"type":"token","platform":"android","token":"eBKnTRKyRS-MORE_TOKEN_OF_DOOM","state":"enabled","appversion":"1.6.004"},"token":"eBKnTRKyRS-SO_MANY_TOKENS"}
Feb 8, 2021 09:25:57:081 PM DEBUG EventSever: Connection not yet authenticated, adding message to queue
Feb 8, 2021 09:25:57:087 PM DEBUG Real value of PRIVACY is:0
Feb 8, 2021 09:25:57:148 PM DEBUG current version: 1.6.004 & available version 1.6.004
Feb 8, 2021 09:25:57:167 PM DEBUG EventSever: Real-time event: {"version":"6.1.11","type":"","status":"Success","event":"auth","reason":""}
Feb 8, 2021 09:25:57:167 PM DEBUG EventSever: Sending pending messages, as auth confirmation received
Feb 8, 2021 09:25:57:167 PM DEBUG EventSever: sendMessage: received->{"event":"push","data":{"type":"token","platform":"android","token":"eBKnTRKyRS-MY_TOKEN","state":"enabled","appversion":"1.6.004"},"token":"eBKnTRKyRS-MY_TOKEN"}
Feb 8, 2021 09:25:57:168 PM DEBUG EventServer: ok to send message
Feb 8, 2021 09:25:57:182 PM DEBUG CACHE: found for key: cached_timezone with expiry of:86400s
Feb 8, 2021 09:25:57:182 PM DEBUG CACHE: cached value for key:cached_timezone is good as 624 <86400
Feb 8, 2021 09:25:57:183 PM DEBUG Timezone API response is:America/New_York
Feb 8, 2021 09:25:59:581 PM INFO --------->Setting up network state handlers....
Feb 8, 2021 09:25:59:582 PM INFO --------->Setting up global key handler...
Feb 8, 2021 09:26:28:661 PM INFO user exited app
Feb 8, 2021 09:26:30:458 PM INFO ******* app .run device ready
Feb 8, 2021 09:26:30:461 PM INFO Device is ready
Feb 8, 2021 09:26:30:461 PM INFO setting size
Feb 8, 2021 09:26:30:462 PM DEBUG UA is mozilla/5.0 (linux; android 11; sm-g986u1 build/rp1a.200720.012; wv) applewebkit/537.36 (khtml, like gecko) version/4.0 chrome/88.0.4324.152 mobile safari/537.36
Feb 8, 2021 09:26:30:462 PM INFO You are running on android
Feb 8, 2021 09:26:30:463 PM DEBUG Inside configureStorageDB
Feb 8, 2021 09:26:30:463 PM DEBUG configureStorageDB: trying order:["asyncStorage","localStorageWrapper"]
Feb 8, 2021 09:26:30:487 PM INFO configureStorageDB:localforage driver for storage:asyncStorage
Feb 8, 2021 09:26:30:487 PM DEBUG configureStorageDB:Making sure this storage driver works...
Feb 8, 2021 09:26:30:496 PM DEBUG resize/orient: 412(w) * 839(h)
Feb 8, 2021 09:26:30:516 PM DEBUG configureStorageDB:test get/set worked, this driver is ok...
Feb 8, 2021 09:26:30:518 PM INFO localforage driver:asyncStorage
Feb 8, 2021 09:26:30:518 PM INFO CloudSync: Syncing with cloud if enabled...
Feb 8, 2021 09:26:30:520 PM INFO user profile encrypted, decoding...
Feb 8, 2021 09:26:30:542 PM DEBUG deobfuscate: before:4040 after:16668 scheme:lzs
Feb 8, 2021 09:26:30:543 PM INFO Cloud sync is disabled, exiting...
Feb 8, 2021 09:26:30:544 PM INFO Cloudsync operation complete, continuing...
Feb 8, 2021 09:26:30:547 PM INFO >>>>No data to import....
Feb 8, 2021 09:26:30:547 PM INFO Updating statusbar
Feb 8, 2021 09:26:30:551 PM INFO Retrieving language before init is called...
Feb 8, 2021 09:26:30:552 PM INFO No language set, switching to en
Feb 8, 2021 09:26:30:557 PM INFO Device Language is:en
Feb 8, 2021 09:26:30:558 PM INFO >>>>Language to be used:en
Feb 8, 2021 09:26:30:558 PM INFO App Version: 1.6.004
Feb 8, 2021 09:26:30:559 PM DEBUG isFirstUse returned: false
Feb 8, 2021 09:26:30:560 PM DEBUG last state=app.log param=[object Object]
Feb 8, 2021 09:26:30:561 PM INFO Language file loaded, continuing with rest
Feb 8, 2021 09:26:30:561 PM INFO ZMData init: checking for stored variables & setting up log file
Feb 8, 2021 09:26:30:565 PM INFO Checking for new version updates...
Feb 8, 2021 09:26:30:622 PM INFO Setting up pause and resume handler AFTER language is loaded...
Feb 8, 2021 09:26:30:622 PM DEBUG Android detected, using cordova-multiwindow plugin for onStop/onStart instead
Feb 8, 2021 09:26:30:628 PM INFO user profile encrypted, decoding...
Feb 8, 2021 09:26:30:647 PM DEBUG deobfuscate: before:4040 after:16668 scheme:lzs
Feb 8, 2021 09:26:30:655 PM INFO Setting NVR init bandwidth to: highbw
Feb 8, 2021 09:26:30:656 PM INFO NVR init retrieved store loginData, marking init as complete
Feb 8, 2021 09:26:30:656 PM DEBUG Setting cordova header X-ZmNinja to zmNinja_1.6.004
Feb 8, 2021 09:26:30:656 PM INFO >>>> Disabling strict SSL checking (turn off in Dev Options if you can't connect)
Feb 8, 2021 09:26:30:658 PM INFO >>> Android: enabling inline image view for self signed certs
Feb 8, 2021 09:26:30:659 PM INFO Inside init-complete in app.js: All init over, going to portal login
Feb 8, 2021 09:26:30:665 PM DEBUG --> SSL is permissive, will allow any certs. Use at your own risk.
Feb 8, 2021 09:26:30:699 PM INFO Entering Portal Main
Feb 8, 2021 09:26:30:768 PM DEBUG Inside Portal login Enter handler
Feb 8, 2021 09:26:30:769 PM INFO User credentials are provided
Feb 8, 2021 09:26:30:769 PM INFO not checking for touchID
Feb 8, 2021 09:26:30:769 PM DEBUG unlock called with check PIN=true
Feb 8, 2021 09:26:30:770 PM DEBUG PIN code entered is correct, or there is no PIN set
Feb 8, 2021 09:26:30:770 PM INFO Cancelling zmAutologin timer
Feb 8, 2021 09:26:30:770 PM DEBUG ------> Not starting login timer for token. We will start a one time timer when we know how soon the access token will live
Feb 8, 2021 09:26:30:771 PM DEBUG Inside _doLogin()
Feb 8, 2021 09:26:30:772 PM DEBUG No need for re-captcha checks with tokens
Feb 8, 2021 09:26:30:773 PM DEBUG Resetting zmCookie...
Feb 8, 2021 09:26:30:773 PM INFO Detected token login supported
Feb 8, 2021 09:26:30:778 PM INFO Access token still has 105 minutes left, using it
Feb 8, 2021 09:26:30:778 PM INFO ----> Setting token re-login after 6300 seconds
Feb 8, 2021 09:26:30:783 PM DEBUG auth-success broadcast:Successful
Feb 8, 2021 09:26:30:790 PM DEBUG _doLogoutAndLogin: Clearing cookies
Feb 8, 2021 09:26:30:791 PM INFO Adding to chain stack: MYURL.duckdns.org/zm>https://MYURL.duckdns.org/zm
Feb 8, 2021 09:26:30:791 PM INFO Fallback of MYURL.duckdns.org/zm is
Feb 8, 2021 09:26:30:792 PM INFO reached end of chain loop
Feb 8, 2021 09:26:30:792 PM INFO No need to do a reachability test, as there are no fallbacks
Feb 8, 2021 09:26:30:801 PM INFO No need for logout!
Feb 8, 2021 09:26:30:802 PM DEBUG Inside _doLogin()
Feb 8, 2021 09:26:30:803 PM DEBUG No need for re-captcha checks with tokens
Feb 8, 2021 09:26:30:803 PM DEBUG Resetting zmCookie...
Feb 8, 2021 09:26:30:804 PM INFO Detected token login supported
Feb 8, 2021 09:26:30:805 PM INFO Access token still has 105 minutes left, using it
Feb 8, 2021 09:26:30:805 PM INFO ----> Setting token re-login after 6300 seconds
Feb 8, 2021 09:26:30:809 PM DEBUG auth-success broadcast:Successful
Feb 8, 2021 09:26:30:813 PM DEBUG PortalLogin: auth success
Feb 8, 2021 09:26:30:814 PM DEBUG getAPIversion called with https://MYURL.duckdns.org/zm/api/host/getVersion.json?&token=<removed>
Feb 8, 2021 09:26:30:840 PM DEBUG CACHE: found for key: cached_api_version with expiry of:86400s
Feb 8, 2021 09:26:30:843 PM DEBUG CACHE: cached value for key:cached_api_version is good as 658 <86400
Feb 8, 2021 09:26:30:843 PM DEBUG snapshot supported in image.php
Feb 8, 2021 09:26:30:877 PM DEBUG obfuscate: original:16668 obfuscated:4040 scheme:lzs
Feb 8, 2021 09:26:30:881 PM DEBUG Setting server version to:1.34.23
Feb 8, 2021 09:26:30:881 PM DEBUG getAPI version succeeded with 1.34.23
Feb 8, 2021 09:26:30:886 PM INFO Got API version: 1.34.23
Feb 8, 2021 09:26:30:887 PM INFO First invocation of TimeZone, asking server
Feb 8, 2021 09:26:30:888 PM INFO EventSever: Initializing Websocket with URL wss://MYURL.duckdns.org:9000
Feb 8, 2021 09:26:30:888 PM DEBUG EventSever: Using native websockets...
Feb 8, 2021 09:26:30:889 PM DEBUG Calling pushInit()
Feb 8, 2021 09:26:30:889 PM INFO EventSever: Setting up push registration
Feb 8, 2021 09:26:30:899 PM DEBUG Transitioning state to: app.log with param {}
Feb 8, 2021 09:26:30:906 PM DEBUG push: permissions are already enabled
Feb 8, 2021 09:26:30:907 PM DEBUG push: got token:eBKnTRKyRS-MY_TOKEN
Feb 8, 2021 09:26:30:907 PM DEBUG push: setting up onMessageReceived...
Feb 8, 2021 09:26:30:909 PM DEBUG push: Channel created: zmninja
Feb 8, 2021 09:26:30:944 PM DEBUG EventSever: WebSocket open called with:{"webSocketId":"SOCKET_TO_ME","code":101}
Feb 8, 2021 09:26:30:945 PM INFO EventSever: openHandshake: Websocket open, sending Auth
Feb 8, 2021 09:26:30:946 PM DEBUG EventSever: sendMessage: received->{"event":"auth","data":{"user":"MYUSER",<password removed>,"monlist":"1,2","intlist":"0,0","appversion":"1.6.004"},"token":"eBKnTRKyRS-MY_TOKEN"}
Feb 8, 2021 09:26:30:946 PM DEBUG EventServer: ok to send message
Feb 8, 2021 09:26:30:948 PM DEBUG EventSever: openHandShake: state of push is enabled
Feb 8, 2021 09:26:30:948 PM DEBUG EventSever: sendMessage: received->{"event":"push","data":{"type":"token","platform":"android","token":"eBKnTRKyRS-MY_TOKEN","state":"enabled","appversion":"1.6.004"},"token":"eBKnTRKyRS-MY_TOKEN"}
Feb 8, 2021 09:26:30:949 PM DEBUG EventSever: Connection not yet authenticated, adding message to queue
Feb 8, 2021 09:26:30:950 PM DEBUG Real value of PRIVACY is:0
Feb 8, 2021 09:26:31:010 PM DEBUG current version: 1.6.004 & available version 1.6.004
Feb 8, 2021 09:26:31:036 PM DEBUG EventSever: Real-time event: {"reason":"","version":"6.1.11","type":"","status":"Success","event":"auth"}
Feb 8, 2021 09:26:31:037 PM DEBUG EventSever: Sending pending messages, as auth confirmation received
Feb 8, 2021 09:26:31:037 PM DEBUG EventSever: sendMessage: received->{"event":"push","data":{"type":"token","platform":"android","token":"eBKnTRKyRS-MY_TOKEN","state":"enabled","appversion":"1.6.004"},"token":"eBKnTRKyRS-MY_TOKEN"}
Feb 8, 2021 09:26:31:038 PM DEBUG EventServer: ok to send message
Feb 8, 2021 09:26:31:039 PM DEBUG CACHE: found for key: cached_timezone with expiry of:86400s
Feb 8, 2021 09:26:31:040 PM DEBUG CACHE: cached value for key:cached_timezone is good as 658 <86400
Feb 8, 2021 09:26:31:040 PM DEBUG Timezone API response is:America/New_York
Feb 8, 2021 09:26:33:477 PM INFO --------->Setting up network state handlers....
Feb 8, 2021 09:26:33:478 PM INFO --------->Setting up global key handler...
Feb 8, 2021 09:27:13:949 PM INFO file location:file:///data/user/0/com.pliablepixels.zmninja_pro/files/zmNinjaLog.txt
zmNinjaLog.txt
Displaying zmNinjaLog.txt.
