Page 1 of 1
Latests builds crash
Posted: Fri Feb 12, 2021 9:18 pm
by Mister_Slowhand
I'm on Ubuntu 20LTS, and the recent builds are crashing. Everything was working perfectly so far (1.35 already)
At first, I let the memory settings, I used 100 frames, then I tried with only 2 but same result. Though I have enough memory :
              total        used        free      shared  buff/cache   available
Mem:           11Gi       3,6Gi       206Mi        82Mi       7,9Gi       7,7Gi
Swap:            0B          0B          0B
Here is what I have in the log with latest version (1.35.18~20210212115535-focal), see that zms keep crashing :
2021-02-12 22:05:47	zmdc		155698	ERR	'zmc -m 4' exited abnormally, exit status 11	zmdc.pl	-
2021-02-12 22:05:42	zmdc		155698	ERR	'zmc -m 7' exited abnormally, exit status 11	zmdc.pl	-
2021-02-12 22:05:42	zmc_m4		156019	ERR	Failed to capture image from monitor 4 Etage (1/1)]	zmc.cpp	333
2021-02-12 22:05:42	zmdc		155698	ERR	'zmc -m 2' exited abnormally, exit status 11	zmdc.pl	-
2021-02-12 22:05:36	zmu		156112	ERR	Can't connect to capture daemon: 6 Ext Fr]	zmu.cpp	488
2021-02-12 22:05:36	zmu		156112	ERR	Can't open memory map file /dev/shm/zm.mmap.6, probably not enough space free: No such file or directory]	zm_monitor.cpp	868
2021-02-12 22:05:35	zmu		156104	ERR	Can't connect to capture daemon: 5 Ext Bk]	zmu.cpp	488
2021-02-12 22:05:35	zmu		156104	ERR	Can't open memory map file /dev/shm/zm.mmap.5, probably not enough space free: No such file or directory]	zm_monitor.cpp	868
2021-02-12 22:05:32	zmdc		155698	ERR	'zmc -m 6' exited abnormally, exit status 11	zmdc.pl	-
2021-02-12 22:05:32	zmdc		155698	ERR	'zmc -m 5' exited abnormally, exit status 11	zmdc.pl	-
2021-02-12 22:05:32	zmdc		155698	ERR	'zmc -m 3' exited abnormally, exit status 11	zmdc.pl	-
2021-02-12 22:05:30	zmc_m3		155733	ERR	Failed to capture image from monitor 3 RdC (1/1)]	zmc.cpp	333
2021-02-12 22:05:06	zmdc		155698	ERR	'zmc -m 4' exited abnormally, exit status 11	zmdc.pl	-
2021-02-12 22:05:01	zmdc		155698	ERR	'zmc -m 7' exited abnormally, exit status 11	zmdc.pl	-
2021-02-12 22:05:01	zmdc		155698	ERR	'zmc -m 6' exited abnormally, exit status 11	zmdc.pl	-
2021-02-12 22:05:01	zmdc		155698	ERR	'zmc -m 5' exited abnormally, exit status 11	zmdc.pl	-
2021-02-12 22:05:01	zmc_m4		155743	ERR	Failed to capture image from monitor 4 Etage (1/1)]	zmc.cpp	333
2021-02-12 22:05:01	zmdc		155698	ERR	'zmc -m 2' exited abnormally, exit status 11	zmdc.pl	-
2021-02-12 22:04:46	zmc_m3		155733	ERR	Failed to capture image from monitor 3 RdC (1/1)]	zmc.cpp	333
2021-02-12 22:04:38	zms_m3		155897	ERR	Backtrace 7: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x43afe) [0x56534a074afe]]	zm_signal.cpp	100
2021-02-12 22:04:38	zms_m3		155897	ERR	Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7f3c010560b3]]	zm_signal.cpp	100
2021-02-12 22:04:38	zms_m3		155897	ERR	Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x4262a) [0x56534a07362a]]	zm_signal.cpp	100
2021-02-12 22:04:38	zms_m3		155897	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x8be38) [0x56534a0bce38]]	zm_signal.cpp	100
2021-02-12 22:04:38	zms_m3		155897	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x85863) [0x56534a0b6863]]	zm_signal.cpp	100
2021-02-12 22:04:38	zms_m3		155897	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x7050d) [0x56534a0a150d]]	zm_signal.cpp	100
2021-02-12 22:04:38	zms_m3		155897	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0) [0x7f3c037093c0]]	zm_signal.cpp	100
2021-02-12 22:04:38	zms_m3		155897	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xdbe5a) [0x56534a10ce5a]]	zm_signal.cpp	100
2021-02-12 22:04:38	zms_m3		155897	ERR	Signal address is (nil), from 0x56534a0a150d]	zm_signal.cpp	79
2021-02-12 22:04:38	zms_m3		155897	ERR	Got signal 11 (Segmentation fault), crashing]	zm_signal.cpp	49
2021-02-12 22:04:37	zms_m6		155890	ERR	Backtrace 7: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x43afe) [0x55be5dac5afe]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m6		155890	ERR	Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7f5f6331c0b3]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m6		155890	ERR	Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x4262a) [0x55be5dac462a]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m6		155890	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x8be38) [0x55be5db0de38]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m5		155889	ERR	Backtrace 7: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x43afe) [0x555a9c5b2afe]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m3		155888	ERR	Backtrace 7: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x43afe) [0x557496978afe]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m6		155890	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x85863) [0x55be5db07863]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m7		155891	ERR	Backtrace 7: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x43afe) [0x556a16a9fafe]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m6		155890	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x7050d) [0x55be5daf250d]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m3		155888	ERR	Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7f65cc5520b3]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m5		155889	ERR	Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7f8e527130b3]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m7		155891	ERR	Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7f8f1627b0b3]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m3		155888	ERR	Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x4262a) [0x55749697762a]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m6		155890	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0) [0x7f5f659cf3c0]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m5		155889	ERR	Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x4262a) [0x555a9c5b162a]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m7		155891	ERR	Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x4262a) [0x556a16a9e62a]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m3		155888	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x8be38) [0x5574969c0e38]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m6		155890	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xdbe5a) [0x55be5db5de5a]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m5		155889	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x8be38) [0x555a9c5fae38]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m7		155891	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x8be38) [0x556a16ae7e38]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m6		155890	ERR	Signal address is (nil), from 0x55be5daf250d]	zm_signal.cpp	79
2021-02-12 22:04:37	zms_m3		155888	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x85863) [0x5574969ba863]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m5		155889	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x85863) [0x555a9c5f4863]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m7		155891	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x85863) [0x556a16ae1863]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m6		155890	ERR	Got signal 11 (Segmentation fault), crashing]	zm_signal.cpp	49
2021-02-12 22:04:37	zms_m3		155888	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x7050d) [0x5574969a550d]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m5		155889	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x7050d) [0x555a9c5df50d]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m7		155891	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x7050d) [0x556a16acc50d]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m3		155888	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0) [0x7f65cec053c0]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m5		155889	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0) [0x7f8e54dc63c0]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m3		155888	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xdbe5a) [0x557496a10e5a]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m7		155891	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x153c0) [0x7f8f1892e3c0]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m5		155889	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xdbe5a) [0x555a9c64ae5a]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m3		155888	ERR	Signal address is (nil), from 0x5574969a550d]	zm_signal.cpp	79
2021-02-12 22:04:37	zms_m7		155891	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xdbe5a) [0x556a16b37e5a]]	zm_signal.cpp	100
2021-02-12 22:04:37	zms_m5		155889	ERR	Signal address is (nil), from 0x555a9c5df50d]	zm_signal.cpp	79
2021-02-12 22:04:37	zms_m3		155888	ERR	Got signal 11 (Segmentation fault), crashing]	zm_signal.cpp	49
2021-02-12 22:04:37	zms_m7		155891	ERR	Signal address is (nil), from 0x556a16acc50d]	zm_signal.cpp	79
2021-02-12 22:04:37	zms_m5		155889	ERR	Got signal 11 (Segmentation fault), crashing]	zm_signal.cpp	49
2021-02-12 22:04:37	zms_m7		155891	ERR	Got signal 11 (Segmentation fault), crashing]	zm_signal.cpp	49
2021-02-12 22:04:25	zmsystemctl		155651	INF	Redirecting command through systemctl	zmsystemctl.pl	-
Is there anything more that you'd need ?
Re: Latests builds crash
Posted: Sat Feb 13, 2021 6:42 am
by Magic919
Best thing is to mention it on Slack.
Posted: Wed Mar 03, 2021 2:54 pm
by Mister_Slowhand
I've reverted to 35.16 while i was away, now I tried today the latest 35.19 and still crashing.
Here is my syslog :
Mar  3 15:48:09 services zmc_m6[808424]: ERR [zmc_m6] [Failed to capture image from monitor 6 Ext Fr (1/1)]
Mar  3 15:48:11 services zmwatch[805304]: ERR [Memory map file '/dev/shm/zm.mmap.3' does not exist in zmMemAttach.  zmc might not be running.]
Mar  3 15:48:11 services undef[808337]: ERR [undef] [Backtrace 0: /usr/bin/zmc(+0xbdafa) [0x55e748172afa]]
Mar  3 15:48:11 services undef[808337]: ERR [undef] [Backtrace 3: /usr/bin/zmc(+0x82088) [0x55e748137088]]
Mar  3 15:48:11 services undef[808337]: ERR [undef] [Backtrace 4: /usr/bin/zmc(+0x75dcf) [0x55e74812adcf]]
Mar  3 15:48:11 services undef[808337]: ERR [undef] [Backtrace 5: /usr/bin/zmc(+0x417e3) [0x55e7480f67e3]]
Mar  3 15:48:11 services undef[808337]: ERR [undef] [Backtrace 6: /usr/bin/zmc(+0x3eb53) [0x55e7480f3b53]]
Mar  3 15:48:11 services undef[808337]: ERR [undef] [Backtrace 8: /usr/bin/zmc(+0x4144e) [0x55e7480f644e]]
Mar  3 15:48:11 services zmdc[805151]: ERR ['zmc -m 4' exited abnormally, exit status 11]
Mar  3 15:48:12 services undef[808317]: ERR [undef] [Backtrace 0: /usr/bin/zmc(+0xbdafa) [0x561094ce9afa]]
Mar  3 15:48:12 services undef[808317]: ERR [undef] [Backtrace 3: /usr/bin/zmc(+0x82088) [0x561094cae088]]
Mar  3 15:48:12 services undef[808317]: ERR [undef] [Backtrace 4: /usr/bin/zmc(+0x75dcf) [0x561094ca1dcf]]
Mar  3 15:48:12 services undef[808317]: ERR [undef] [Backtrace 5: /usr/bin/zmc(+0x417e3) [0x561094c6d7e3]]
Mar  3 15:48:12 services undef[808317]: ERR [undef] [Backtrace 6: /usr/bin/zmc(+0x3eb53) [0x561094c6ab53]]
Mar  3 15:48:12 services undef[808317]: ERR [undef] [Backtrace 8: /usr/bin/zmc(+0x4144e) [0x561094c6d44e]]
Mar  3 15:48:12 services zmdc[805151]: ERR ['zmc -m 7' exited abnormally, exit status 11]
Mar  3 15:48:22 services zmwatch[805304]: ERR [Memory map file '/dev/shm/zm.mmap.7' does not exist in zmMemAttach.  zmc might not be running.]
Mar  3 15:48:22 services undef[808344]: ERR [undef] [Backtrace 0: /usr/bin/zmc(+0xbdafa) [0x559f9dc1dafa]]
Mar  3 15:48:22 services undef[808344]: ERR [undef] [Backtrace 3: /usr/bin/zmc(+0x82088) [0x559f9dbe2088]]
Mar  3 15:48:22 services undef[808344]: ERR [undef] [Backtrace 4: /usr/bin/zmc(+0x75dcf) [0x559f9dbd5dcf]]
Mar  3 15:48:22 services undef[808344]: ERR [undef] [Backtrace 5: /usr/bin/zmc(+0x417e3) [0x559f9dba17e3]]
Mar  3 15:48:22 services undef[808344]: ERR [undef] [Backtrace 6: /usr/bin/zmc(+0x3eb53) [0x559f9db9eb53]]
Mar  3 15:48:22 services undef[808344]: ERR [undef] [Backtrace 8: /usr/bin/zmc(+0x4144e) [0x559f9dba144e]]
Mar  3 15:48:22 services zmdc[805151]: ERR ['zmc -m 5' exited abnormally, exit status 11]
Mar  3 15:48:22 services zmc_m3[808501]: ERR [zmc_m3] [Failed to capture image from monitor 3 RdC (1/1)]
Mar  3 15:48:22 services zmc_m7[808524]: ERR [zmc_m7] [Unable to open input http://192.168.7.15/videostream.asf?user=USER&pwd=PASSWORD due to: Immediate exit requested]
Mar  3 15:48:22 services undef[808524]: ERR [undef] [Backtrace 0: /usr/bin/zmc(+0xbdafa) [0x556810a76afa]]
Mar  3 15:48:22 services undef[808524]: ERR [undef] [Backtrace 3: /usr/bin/zmc(+0x82088) [0x556810a3b088]]
Mar  3 15:48:22 services undef[808524]: ERR [undef] [Backtrace 4: /usr/bin/zmc(+0x75dcf) [0x556810a2edcf]]
Mar  3 15:48:22 services undef[808524]: ERR [undef] [Backtrace 5: /usr/bin/zmc(+0x417e3) [0x5568109fa7e3]]
Mar  3 15:48:22 services undef[808524]: ERR [undef] [Backtrace 6: /usr/bin/zmc(+0x3eb53) [0x5568109f7b53]]
Mar  3 15:48:22 services undef[808524]: ERR [undef] [Backtrace 8: /usr/bin/zmc(+0x4144e) [0x5568109fa44e]]
Mar  3 15:48:22 services zmdc[805151]: ERR ['zmc -m 7' exited abnormally, exit status 11]
ffmpeg access to cameras is fine too.
About Slack, can you point me to it, as I'm not a dev, I'm not using it ?
Posted: Wed Mar 03, 2021 7:01 pm
by Magic919
Posted: Sat Mar 06, 2021 2:41 am
by dougmccrary
FWIW, I'm running 20.04.2lts and 1.35.19. It's got problems of course, but not crashing.
Just went to 1.35.20, also not crashing.
Posted: Sat Mar 06, 2021 11:52 am
by Magic919
Good to know. Thanks.
