Long time Linux user, open source enthusiast and Perl guy trying to get a grip on a surveillance system for my home.
I don't really expect any help/support, just wanted to report what happens if a ZM newbie (but otherwise hopefully not
totally incompetent) makes first encounters. Maybe some dev finds it enlightening.
At least I think ZM could benefit from such "fresh insight".
Scene:
ZoneMinder 1.34.23 running as a TurnkeyLinux appliance (https://www.turnkeylinux.org/zoneminder) on Proxmox
on a nifty https://www.gigabyte.com/Enterprise/Ser ... ST0-rev-11
The VM got 8 cores 4GB RAM and 1TB disk space
Bought two Reolink RLC-410 PoE cams and they do work ... sort of.
Well, first off: Would it be possible - by any means - to pause the log??? I am getting a twitching eye when there are like 20 messages per second (timestaps prove I do not exaggerate) and I do try to copy and paste one of them.
When I connected one cam, after much ado and reading (viewtopic.php?t=29143) it did work in sufficient quality.
When I connected the second cam, only one of them works. Sometimes "Cam1", sometimes "cam2", while wathing this non-deterministic spectacle, the log errors and warnings of zm -s 3 crashing error code 255 fly by. Sorry - no copy & paste, no better memo because I get 1 second to watch it and then the log message is gone with the wind.
Not sure who thought the Log window could be useful at all this way.
Image buffer too small... again. So if I add one cam, I have to increase the buffers in ALL cam (monitor?) configurations? srsly?
Ok, I'll do:
zmc -m 3 crashed, signal 6 (that is level INF - by the way? yes?)
Great now Cam1 works (before that Cam2 did work).
An error, Timezone not being configured, appears - among the myriad of log messages flying by. Of course it is configured (Europe/Prague). *shrug*
Yeah - I know I can filter to see only warnings and up, still I have only one second to try to copy & paste, because there is always said timezone error. goddammit. Ok, dpkg-reconfigure tzdata seems to have stuffed that mouth.
Hm. I see there might be a problem with hardware resources. 4GB RAM not being enough for two 5MP cams... sigh, will give it more and then some day look at the memory consumption atrocities that evidently do happen somewhere in the implementation.
edit: yeah. one 5MP cam takes 57% of SHM if you have 4GB RAM, so 8GB RAM is good for 3 cams - I planned 10 cams that would be 24GB straight.
