Marks Zm Event Notification findings in zm images?
Axelb1971
Post by Axelb1971 »
I am not sure, if I understood the zm event notification plugin with ML Hooks right.
I would like to use this plugin to mark persons, animals, objects within Zoneminder. I don't want to use the notification service, only marking within zm.
In my actual setup the plugin doesn't add text for example to the "cause" field and it doesn't mark recognized items in den zm images.
Should it do this?
Axel
Re: Marks Zm Event Notification findings in zm images?
ZMES should show the object that detected and write this to ZM.
Axelb1971
Post by Axelb1971 »
thanks, then I have to search for the mistake in my setup
