The cameras are configured the exact same way 1080p @ 15fps.
The configuration on zoneminder's side is also the same for both cameras. Streams on both work fine but event playback only works on 1.
I did a test and forced an event on both cameras, then downloaded the mp4 on each.
The file sizes are very similar.
When I open each in vlc, one of the files has 16 seconds of footage and the other shows 0:00/0:00. The video is basically empty except for the very first frame.
Also for some reason the one that doesn't work is sitting at an even 30.00 frames/sec with a much higher data rate then the one that works.
I took a great deal of care to make sure that every setting on each camera is absolutely identical (both in ZM and out). What am I missing?
