Can't locate ZoneMinder/Control/onvif in @INC
Posted: Sun Mar 07, 2021 2:49 am
Hi!
Recently updated to these rpms:
zoneminder-httpd-1.34.23-1.el7.x86_64
zoneminder-1.34.23-1.el7.x86_64
zoneminder-common-1.34.23-1.el7.x86_64
and after rebooting, I am seeing these errors:
Am I missing a perl library, or is a path missing from @INC?
--edit --
That's a very confusing error too -- it looks like there's a problem with a require statement in the onvif.pem file, however it then goes on to say that that onvif file can't be found?
-rw-r--r--. 1 root root 8876 Jan 24 09:29 /usr/share/perl5/vendor_perl/ZoneMinder/Control/onvif.pm
Mar 6 18:47:54 zoneminder zmcontrol_6[6604]: FAT [Can't load ZoneMinder::Control::onvif#012Global symbol "$this" requires explicit package name at /usr/share/perl5/vendor_perl/ZoneMinder/Control/onvif.pm line 68.#012Compilation failed in require at /usr/share/perl5/vendor_perl/Module/Load.pm line 27.#012Can't locate ZoneMinder/Control/onvif in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5) at /usr/share/perl5/vendor_perl/Module/Load.pm line 27.]
Mar 6 18:47:54 zoneminder zmdc[6343]: ERR ['zmcontrol.pl --id 6' exited abnormally, exit status 255]
--edit --
