Zoneminder master 1.35.21~20210316201259-focal , USB camera monitor problem [Solved]
bkjaya1952
Post by bkjaya1952 »
I have tested the latest release of Zoneminder master 1.35.21~20210316201259-focal ( released today) with a network ip camera and a USB camera.
The network ip camera monitor is working properly .
But the USB camera monitor has a blank streaming view.
Error logs are attached
bkjaya1952
Re: Zoneminder master 1.35.21~20210316201259-focal , USB camera monitor problem
Although the monitor streaming is not viewable ,when you change the monitor to Record , recordings can be viewed as follows
Screenshot from 2021-03-17 19-14-09.png (560.42 KiB) Viewed 2759 times
Other observations:-
The filters can't be saved.
Modect and Mocord are not working
I've been seeing the same since last week. Also javascript in the web gui not working. I also have the same version installed and seeing several variations of those errors.
bkjaya1952
There is no luck even with the latest Zoneminder master 1.35.21~20210317131009-focal .
Screenshot from 2021-03-17 22-52-36.png (240.09 KiB) Viewed 2746 times
Screenshot from 2021-03-17 22-59-04.png (387.65 KiB) Viewed 2746 times
bkjaya1952
Re: Zoneminder master 1.35.21~20210316201259-focal , USB camera monitor problem [Solved]
The monitor problem is solved in the latest Zoneminder master 1.35.21~20210317171513-focal released today !
Thank you very much for solving the problem ! :D :D
