Page 1 of 1
HELP, Zoenminder just isnt working.
Posted: Wed Mar 17, 2021 2:22 pm
by whitekid.exe
Hello, so back in december i had zoneminder working but couldn't get a USB drive to work so thought i would start a fresh, did this and haven't had it working since, i've done numerous fresh installs of buster lite and normal buster on my raspberry pi 4 4gb, help me please i keep getting this error.
2021-03-17 14:15:48 zmdc 660 ERR 'zmfilter.pl --filter_id=2 --daemon' exited abnormally, exit status 9 zmdc.pl
any help is welcome, maybe if anyone has a good tutorial for me to follow that would be great as i have the zmninja app on my phone and i had to reinstall zoneminder because the api wasn't working.
please help i love this project and dont wanna use something else.
many thanks Jack
Re: HELP, Zoenminder just isnt working.
Posted: Thu Mar 18, 2021 2:33 pm
by alabamatoy
ZM on a Pi seems like a significantly heavy load for a Pi. I know they are amazing little boxes, but still, its a lot to ask of the little bugger. How many cameras do you expect to load onto it?
Posted: Thu Mar 18, 2021 4:35 pm
by whitekid.exe
I’m thinking of moving over to a more powerful system now thank you
Posted: Sun Dec 12, 2021 2:09 am
by ksatdesign
just for reference to get api working on pi 4 with buster
nano /usr/share/zoneminder/www/api/app/Config/database.php.default
edit lines from 65
class DATABASE_CONFIG {
public $default = array(
'datasource' => 'Database/Mysql',
'persistent' => false,
'login' => your zmuser,
'password' => your db password,
'database' => your zmdb,
'ssl_ca' =>
'ssl_key' =>
'ssl_cert' =>
'prefix' => '',
'encoding' => 'utf8',
then save as /usr/share/zoneminder/www/api/app/Config/database.php
nano /etc/apache2/conf-enabled/zoneminder.conf
Replace contents with
AllowOverride All
Require all granted
</Directory>
Alias /zm/cache "/var/cache/zoneminder"
<Directory "/var/cache/zoneminder">
AllowOverride None
<IfModule mod_authz_core.c>
# Apache 2.4
Require all granted
</IfModule>
</Directory>
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
RewriteEngine on
RewriteBase /zm/api
</Directory>
<Directory /usr/share/zoneminder/www/api/app>
RewriteEngine on
RewriteRule ^$ webroot/ [L]
RewriteBase /zm/api
</Directory>
<Directory /usr/share/zoneminder/www/api/app/webroot>
RewriteEngine On
RewriteRule ^ index.php [L]
RewriteBase /zm/api
</Directory>
save
service apache2 restart
systemctl restart zoneminder
and it should work
P.S. my setup atm is a pi 400 with a old 500gb (5400rpm) 2.5 hdd connected with ugreen usb3 2 sata https://www.amazon.com.au/gp/product/B0 ... UTF8&psc=1
I run 5 cameras set to modetect and tuned to eliminate trees moving etc and set to remove files more then 7 days old it works great
to make the hdd work (and to ditch sdcard simply install buster on the sd edit the cmdline.txt to be console=serial0,115200 console=tty1 root=/dev/sda2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
and use belancher to clone the sd card to hdd then simply plug hdd into pi (dont put the sdcard in ) and boot make sure to change login from pi -raspberry and enable ssh and expand the rootfs to use the whole drive and set locals with raspi-config
