Check if Monitor is in an Event
phils01
Post by phils01 »
Hi All
Is there any way I can check if a monitor is currently in an Event?
I am writing some remote software that will trigger ZoneMinder usign zmtrigger, but I need to check first if the Monitor is already recording an event.
I can read the database for ene EndTime in the Event, but this is not alway accurate if there was a problem with the previous event or the montior crashes.
Zmtrigger does not start a new event if the monitor is already recording a previous event, but I cannot see where it checks that
Thanks in advance
Phil.
Re: Check if Monitor is in an Event
You can use zmu to query the monitor.
