Unable to send stream frame: Broken pipe
wallacebw
Post by wallacebw »
Not to raise a dead post, but is there a reason that 'Unable to send stream frame: Broken pipe' is still an ERR in v1.34.23?
I was hoping it moved to INFO, as it is filling up my logs.
This occurs when viewing streams in the web interface using brave (chromium based)
REF:
viewtopic.php?f=36&t=26109
Thanks,
Brian
alabamatoy
Re: Unable to send stream frame: Broken pipe
Post by alabamatoy »
I tend to agree that it should be info....I think this is occurring due to slow network connection.
wallacebw
Post by wallacebw »
in my case it is when the client disconnects not speed, as both server and client are are the same subnet with 100+Gb nics (yes, 100 Gigabit, not Megabit)... Second hand hyper-scaler equipment is cheap now. Under $1300 for a 48port 25G switch with 6 x 100G uplinks. Not quiet though :D
https://www.xbyte.com/hw/dell/networkin ... eries.html
Yes, DELL... if you know networking it's all the same 2 or 3 ASICs, as long as it has the feature-set you need, your good. In this case it is a Broadcom Tomahawk
