I'm guessing the multi-server setup comes into play somewhere around the 20-cam point, without severely restricting bandwidth and frame rate. Is there any sort of hardware requirements formula or baseline specs? Any anecdotal stories from large installs? This one is all default, with the exception of increasing buffers on the cam configs. The OS cannot be tuned any tighter. I was gonna build another 7/27 3rd gen machine when I get around to it, but now I'm wondering if I should go bigger, just for a little overhead space?
You can feel it bog a little at the console when it gets busy now. It won't run more than one properly-resourced Windoze VM acceptably, without stopping ZM. -32gig RAM with swap disabled, all NVME/SSD. I can't imagine it would run at all on 16gig with spinning discs and swap enabled.
