Debug non alarm events
Posted: Sun Apr 04, 2021 7:17 pm
I have a new setup of ZM on a new hardware. I am using the same settings in the new ZM like in the in parallel running old ZM (other hardware). The new ZM misses a lot of events ...
I would like to debug the situation by analysing missed event pictures.
How does the pixel diff algorithm work? Is there a tool, which could calculate the pixel difference between two images like ZM to get some stats of the images and visualize the differences? The tool should use the same method of threshold for the pixel diff.
And is it possible to feed old events (or manual alarms without real alarm frames) to ZM to see how it reacts to it with different zone settings?
Any ideas?
Any ideas?
