Upgrade Issue 1.34 ->1.35
Posted: Wed Apr 07, 2021 9:35 pm
Hi
I have run a 6 monitor set up on 1.34 quite happily for a while. Decided that I might like to help with testing, so added the master PPA and upgraded to 1.35.23 using the Ubuntu Software update. The upgrade apparently went smoothly, and I can see my UI as expected, but none of the cameras appear to be capturing, and when I attempt to change Modect to None (The idea to then reset them to modect ) it wont save the status & throws up a 500 error (internal server error?)
It also doesn't show any of the previous captured footage
I wonder if its a codex or decoder problem?
Im using Apache2, MariaDB and Ubuntu 20.04 LTS (Focal) and set it up according to the instructions in the wiki.
Previous to doing the update it was running perfectly
While its not the end of the world, is it something I have done, and how do I fix it or if not is there a simple way to downgrade back to the stable 1.34
If you need more info..chirp up and I will try to provide (I'm not a techie,)
