Page 1 of 1
Installation error in Zoneminder matser 1.35.26~20210413091429-focal [Solved ]
Posted: Tue Apr 13, 2021 4:39 pm
by bkjaya1952
I have tried to install ( fresh installation ) the latest release of Zoneminder master 1.35.26~20210413091429-focal & found the following mysql error
Detected db service is mysql.service
Checking for db
Creating zm db
ERROR 1136 (21S01) at line 793: Column count doesn't match value count at row 1
Error creating db.
dpkg: error processing package zoneminder (--configure):
installed zoneminder package post-installation script subprocess returned error
exit status 1
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
Processing triggers for systemd (245.4-4ubuntu3.5) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
Errors were encountered while processing:
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
Re: Installation error in Zoneminder matser 1.35.26~20210413091429-focal
Posted: Tue Apr 13, 2021 7:30 pm
by DVB Hardware
If you did a clean install then disregard the following:
My upgrade was fine Linux Mint 20.1 ZM 1.35.26~20210413091429-focal from previous version
also installed a kernel update
Jimmy
Posted: Wed Apr 14, 2021 7:10 am
by bkjaya1952
DVB Hardware wrote: Tue Apr 13, 2021 7:30 pm If you did a clean install then disregard the following:
Jimmy
The problem is in the fresh installation..There is no problem in upgrading from previous version.
Posted: Wed Apr 14, 2021 5:07 pm
by iconnor
Just pushed a fix.
Re: Installation error in Zoneminder matser 1.35.26~20210413091429-focal [Solved ]
Posted: Thu Apr 15, 2021 6:31 am
by bkjaya1952
iconnor wrote: Wed Apr 14, 2021 5:07 pm Just pushed a fix.
Thank you Sir !.
Installation problem solved , after using your fix ( fix at the following link ) on the /usr/share/zoneminder/db/zm_create.sql ,
https://github.com/ZoneMinder/zoneminde ... e6c99192d0
Screenshot from 2021-04-15 17-14-19.png (390.55 KiB) Viewed 4753 times
Posted: Sat Apr 17, 2021 3:54 am
by mhamel
I have just run into this myself: I'm afraid its not clear to me how to apply the fix. Do I edit zm_create_sql.in and retry the install, or can I pick up the change via git somehow?
Thanks,
Michael
Posted: Sat Apr 17, 2021 6:17 am
by bkjaya1952
mhamel wrote: Sat Apr 17, 2021 3:54 am I have just run into this myself: I'm afraid its not clear to me how to apply the fix. Do I edit zm_create_sql.in and retry the install, or can I pick up the change via git somehow?
Thanks,
Michael
sudo su
add-apt-repository ppa:iconnor/zoneminder-master
apt update
apt -y install zoneminder
( Now you will see some error message ie Error: Process completed with exit code 100. )
Then go to the following Issac Connor's web link
You can see the corrected lines within the green color block .
Open the file at /usr/share/zoneminder/db/zm_create.sql
sudo gedit /usr/share/zoneminder/db/zm_create.sql
Delete the 793 line of the opened file zm_create.sql .
Then copy Issac Connor's fix at above link marked in green color block and paste at line 793 and save.
Then configure zoneminder and apache as usual.
Please refer the following link for get more details
https://bkjaya.wordpress.com/2020/11/16 ... cal-fossa/
Posted: Sun Apr 18, 2021 6:29 am
by dougmccrary
But now:
1.35.26~20210417163214-focal
- db upgrade fails.
Ran zmupdate manually failed.
Got it to work with the suggested mysql work-around.
Posted: Sun Apr 18, 2021 6:52 am
by bkjaya1952
Thanks,
Michael
It is apparent that the Isaac Cooor's fix has already being included in the latest Zoneminder master 1.35.26~20210417163214-focal
Therefore it is not necessary to apply the fix manually
Posted: Sun Apr 18, 2021 8:03 am
by dougmccrary
May be ok on fresh install, but upgrade fails now. At least for me.
Posted: Sun Apr 18, 2021 5:30 pm
by bkjaya1952
dougmccrary wrote: Sun Apr 18, 2021 8:03 am
Hi dougmccrary,
Even for a fresh install of the above version, ZM will not work unless you drop the zm database & re create
