I have tested The Zoneminder master 1.35.26~20210417163214-focal released today with aUSB camera monitor.
It has been observed that the modect is not working .
The error logs are appended below.
Zoneminder master 1.35.26~20210417163214-focal , modect, - not saving events [ Solved ]
- bkjaya1952
Re: Zoneminder master 1.35.26~20210417163214-focal , modect, mocord- not saving events
The error message is pretty clear. It can't open the directory to put the files in. Could be out of disk space, permissions, etc.
I have the same problem since the last 2 builds. Nothing has changed in my config, plenty of disk space available. Morecord works for me but not Modect. Error message :
Socket /run/zm/zms-613313s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.
- bkjaya1952
Yes Morecord works . Only modect is not workingphgerin wrote: ↑Sun Apr 18, 2021 5:10 pm I have the same problem since the last 2 builds. Nothing has changed in my config, plenty of disk space available. Morecord works for me but not Modect. Error message :
- bkjaya1952
Re: Zoneminder master 1.35.26~20210417163214-focal , modect, - not saving events
Still the modect problem is there in the Zoneminder-master latest 1.35.26~20210419131933-focal & Zoneminder-master latest 1.35.26~20210419131933-bionic
They are working fine for me. Please double check. Send logs
- bkjaya1952
