Onvif camera not working (raspbian)
manny99
Post by manny99 »
Hi to all,
my ONVIF camera not working under zoneminder v1.34.22
In console under monitor I see capturing but ip address is red.
Under source I setting rtsp://admin:xxxxxxxxx@192.168.1.121/onvif1. Also added in options: --rtp-client-port=554
Tried also as rtsp://admin:xxxxxxxxx@192.168.1.121:554/onvif1 but not work. Controls not configured
I checked that this rtsp address work perfectly with VLC but not work with zoneminder.
Any help for this problem?
Re: Onvif camera not working (raspbian)
manny99 wrote: Wed Apr 21, 2021 3:51 pm Hi to all,
What camera are you using? ONVIF does not always work. One sure bet is to get the cam working in VLC then use those settings in Zoneminder. Be aware that the resolution set in Zoneminder has to match the camera output.
manny99
Post by manny99 »
bbunge wrote: Thu Apr 22, 2021 1:40 pm What camera are you using? ONVIF does not always work. One sure bet is to get the cam working in VLC then use those settings in Zoneminder. Be aware that the resolution set in Zoneminder has to match the camera output.
In VLC I see that my cam is H265 1920 x 1080.
I think that the problem is H265.
Is there a setting that I can insert in source --> options?
