Page 1 of 1
Multiple servers
Posted: Wed Apr 21, 2021 8:16 pm
by kradoow
I set up multiple servers (2) for zoneminder. when I log on to servers 1 and 2 I can see all the cameras. I was wondering if it is beneficial to have a few cameras connected to 1 server and the remainder connected to the other. I tried adding one to the new server but it would not display anything. I chose server 2 in the server section of the camera. I have the original server as the storage area and db, is this the correct way to do this? does server 1 need to know anything about server 2 in the zm.conf file? I only setup server 2 in one spot on server one, options -> servers.
also on the servers page of serever1 I see this:
Name Url Path To Index Path To ZMS Path To Api Status Monitors CpuLoad
server1
http://10.1.3.1:80 /zm/index.php /zm/cgi-bin/nph-zms /zm/api NotRunning 10 1.2
server2
http://10.1.3.2:80 /zm/index.php /zm/cgi-bin/nph-zms /zm/api Unknown 0
Hopefully, I made some sense.
Thanks,
John
Re: Multiple servers
Posted: Wed Apr 21, 2021 9:00 pm
by kradoow
I just noticed on server2 that the server says it is stopped, in the upper right even though I can see the cameras. When I hit start->apply it does not change status.
Posted: Wed Apr 21, 2021 9:42 pm
by kradoow
I think I figured it out, because it is working now. I had versions 26 and 23 I looked in the log files and saw a FAT error stating the server was a higher number than the database, so I upgraded sever1 to the same version. For now, it seems to be working.
Posted: Wed Apr 21, 2021 10:06 pm
by kradoow
So I am disappointed I expected CPU and bandwidth levels to drop (kind of be split amongst the servers) when adding another server. I guess I do not quite understand the benefit of having another server. Could someone explain to me the benefits?
Posted: Thu Apr 22, 2021 12:31 pm
by Maximo1970
I also run a multi server setup, but have a separate DB server. My setup has 4 frontend servers, each with three cameras. They vary in terms of CPU load, all down to the camera, location, and amount of activity. I've moved cameras around to try and balance the load, but presently this isn't managed within ZoneMinder.
Posted: Thu Apr 22, 2021 10:27 pm
by Acewiza
Maximo1970 wrote: ↑Thu Apr 22, 2021 12:31 pm
That's like exactly the opposite of what I'm doing. I run 12 cams on one server - the same box that also performs firewall, database, routing, and hosting a wordpress site while being used as my personal workstation. It hums along at an average 70-80% CPU load, driving 4 displays with a montage running somewhere always. It'll only do 1 XP VM, tho. Launching a Win10 Virtualbox session without stopping ZM locks it up - not for lack of RAM.
Posted: Sun Apr 25, 2021 10:08 am
by Bluemax
12 cams on what resolution/fps? How much ram? ZM is in a VM?
Posted: Sun Apr 25, 2021 12:44 pm
by Acewiza
No, straight up, all default. 32Gig. Never uses more than 60% of that resource.
Resolutions vary, mostly pretty high, one VERY high.
I'm curious to know what resource resolution eats, because bandwidth is nominal/small overall.
Generally speaking, ZM is a resource hog. It constitutes >90% of the workload on this busy PC.
Posted: Mon Apr 26, 2021 11:58 am
by Acewiza
ZM never saw a CPU cycle it didn't eat!
Don't get me wrong - I LOVE Zoneminder, compared to the last app I used for this. But it's making me build a new PC for what I am asserting is a not good reason.
It should be an interesting comparo, to see what the same system does on double the hardware....
Posted: Mon Apr 26, 2021 2:25 pm
by Acewiza
Bluemax wrote: ↑Sun Apr 25, 2021 10:08 am
You ask alot of questions...
I can embellish my answers more if needed...
Posted: Mon Apr 26, 2021 9:06 pm
by Bluemax
If i'm not wrong, Zoneminder still runs on RGB that involves YV12->RGB conversion. That costs a lot. I can remember back in the days when Avisynth was upgraded to work natively in YV12. It was a massive speed gain.
But 12 cameras is an impressive count nevertheless. I can barely run one 2160p camera (with 4GB RAM).
Posted: Mon Apr 26, 2021 10:59 pm
by Andyrh
It just depends on your needs, I run 5 cameras, 3,4,4,5,8 mp at frame rates of 10 and 8 FPS. All modect. My Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz runs in the 2-4 load range out of a possible 8. The store is software RAID5.
Memory usage is not bad either:
free -m
total used free shared buff/cache available
Mem: 15936 2875 198 3394 12862 9338
Swap: 4095 44 4051
If I needed 20 or 30 FPS then better HW would be needed, but my needs are modest, just watching the street and yard.
Posted: Tue Apr 27, 2021 1:20 pm
by lbm
kradoow wrote: ↑Wed Apr 21, 2021 10:06 pm
They do not work in a cluster per say. So what you have done, its adding to servers, which uses the same cameras, which would give you the same load on each server. For this usage, its about redudancy, so you would be able to have one server down, without "downtime".
Posted: Tue Apr 27, 2021 4:16 pm
by Acewiza
Needs/wants. Seems like I always need an upgrade and want something better...
10:10:59 up 1 day, 3:40, 1 user, load average: 39.64, 35.99, 34.65
It ran a week like that before I booted it yesterday, actually taching >90% continuously with Montage up. Running around 150°F, so not getting hot. Pretty intense.
Posted: Tue Apr 27, 2021 4:31 pm
by Acewiza
Bluemax wrote: ↑Mon Apr 26, 2021 9:06 pm
Would that explain why Montage alone consumes around 30% of the load? I don't know much about the down-in-the-weeds video stuff, but it sure feels like this code is running in alot of very tight loops.
