Camera Switch to None,Disabled alone
mmaura66
Post by mmaura66 »
I use Zoneminder 1.34.26.
I have 4 cameras working since long time.
I added a camera, it works, but after a certain number of hours, between 24 and 48 the camera deactivates itself.
When activated everything works correctly including movement and motion detection.
I cannot find a corresponding error message and I do not understand what happens with this.
I couldn't find any information in the forum, do you have any idea what could be causing this behavior?
Thank you.
Re: Camera Switch to None,Disabled alone
Weird. Do they all do this?
Perhaps a sick database disk? I'd try adding the camera(s) (clone it if you like) again and see what happens.
swolsen
Post by swolsen »
Could you have a script running via cron job that updates camera through api?
Check your Apache access log for POST /zm/api/monitors/x.json where x is the camera's id. around the time it changes.
Your LOG_LEVEL_WEBLOG would need to be set to INFO I believe for it to be logged.
mmaura66
Post by mmaura66 »
I cloned then deleted the camera, at first nothing, then again same status: None, Disabled.
Then it clicked in my head :shock:
I am using HomeAssistant to switch the global status from ZoneMinder to Modect, Monitor, Stop; but this status had not been saved for the new camera. Also at each change of global status, the camera switches to None, Disabled ...
Thank you for help :roll: .
1.34.27 will contain a fix for this.
To apply the fix yourself look to recent commits to the release-1.34 branch.
https://github.com/ZoneMinder/zoneminde ... 774ddf37aa
