Frames.ibd, Logs.ibd, Stats.ibd too big
BigChris
Post by BigChris »
I have Zoneminder 1.34.26 running in a Docker container on my unraid server.
Unfortunately, Zoneminder is taking up more and more space on my image.
I have swapped out the directory /var/cache/zoneminder. Also the /config
I noticed that the files
are very large.
I don't understand that Frames.ibd doesn't get smaller when I delete recordings, Also I don't understand how to delete the logs.
What can I do to free up space?
burger
Re: Frames.ibd, Logs.ibd, Stats.ibd too big
Post by burger »
DB log settings are in console - options. You can and probably should stop DB logging if you aren't using it. I think stats is also there somewhere.
In Debian based ZM I haven't noticed .ibd files becoming too large. The ibdata file used to get too large (in 1.28) but that was resolved with newer MySQL / ZM. Can't speak for unraid.
fastest way to test streams:
