Mocord Timestamp and playback
DVB Hardware
Post by DVB Hardware »
Hi, I have a problem but shows no error in the log
1. Playback from the live stream fine from console
2. Playing an completed event pixilates for 3-4 sec then plays and timestamp erroneously flashes on off. Both of these never happened before.
3. does the same on the server or another remote browser , Firefox or chrome
Don't know what to check
Jimmy
Re: Mocord Timestamp and playback
the flashing timestamp is a known problem, testing a fix. WIll likely be in 1.36.3.
pixelation? What storage method are you using? Encoding with setting some options like crf can cause this
DVB Hardware
OK timestamp a known issue, I could not find info in forum
I had some errors before using ffmpeg for years , you suggested the settings in the pic below which worked
