Page 1 of 1
Events with zero frames
Posted: Tue Jun 01, 2021 3:10 pm
by yannlieb
I have just updated from the 1.34.x to the 1.36.x line. (Ubuntu 20.04, ARM64).
I have some issues appearing in the event list :
In red boxes, events are with zero frames
In purple boxes, events show also zero frames, but there is definitely a recording saved.
Any idea where I should investigate more?
The only change I did since upgrading was to manually remove the Maximum Image Buffer Size (frames) into the camera config from 75 to 'empty', as mentioned in another thread.
Re: Events with zero frames
Posted: Tue Jun 01, 2021 10:46 pm
by iconnor
You have crashing going on.
Look at your logs.
Posted: Wed Jun 02, 2021 8:31 am
by yannlieb
I still have errors coming in the logs from events of yesterday. I will delete all my past events so that my past problems won't keep polluting the logs, and will analyse from a 'clean' event backlog.
A non-related issue, but I also realised that zmupdate.pl still retrieves version information from the 1.34.x line and not from the 1.36.x :
02/06/2021 10:02 zmupdate 72350 INF Got version: 1.34.26
02/06/2021 10:02 zmupdate 72350 INF Checking for updates
Posted: Mon Jun 07, 2021 8:27 am
by yannlieb
I still have some crashing - mostly due I assume to memory consumption.
In the meantime I would like to clear the records and event which are not relevant (ie recording less than 1Mb), however I haven't been able to figure out the format of the filter "event disk space'. Doesn't seem to be working with absolute values in bytes, or values in the same format as the events list (ie: <999.00Kb)
Posted: Mon Jun 07, 2021 8:36 am
by parky
I cleared my zero events last week after I did a bit of reconfiguring of cameras and got a load of zeros. From the console view list all the events on the server and then just filter by frames and then you can select them by the page for deletion
Posted: Mon Jun 07, 2021 8:45 am
by yannlieb
The thing is that I would like to remove the ones with non-relevant recording, but keep the ones with a proper recording, even if in the event list they are shown with 0 frames.
Right now, I am filtering the events with 0 frames and removing the ones with no or small recording manually, but I would like to transform that into an automatic filter, thus the need of this variable.
Posted: Mon Jun 07, 2021 11:11 pm
by dougmccrary
yannlieb wrote: Mon Jun 07, 2021 8:45 am The thing is that I would like to remove the ones with non-relevant recording, but keep the ones with a proper recording, even if in the event list they are shown with 0 frames.
zero alarm frames?
Maybe post exactly what you want to delete, and a screen shot of what you have for the filter that doesn't seem to work?
Posted: Tue Jun 08, 2021 7:35 am
by yannlieb
dougmccrary wrote: Mon Jun 07, 2021 11:11 pm zero alarm frames?
If you look at my first post, I would like to remove the events boxed in red, because they don't show any frames, and don't have any proper recording. I want to keep the items in purple. They also don't have any frames, but they have a recorded associated
That is the reason I wanted to filter on the event disk space, but I'm open to any suggestion.
Posted: Tue Jun 08, 2021 8:27 am
by dougmccrary
OK, I can't get a filter to work on either event disk space or cause.
But I also have never seen events like that where I cared.
so:
iconnor wrote: Tue Jun 01, 2021 10:46 pm You have crashing going on.
Look at your logs.
is my only suggestion at this point.
Sorry, good luck.
