I have the pre-built Proxmox install of ZM installed (ZM v1.34.25). ZM itself works fine, I can view the camera feeds and record. However, I'm trying to get ZM Event Notification Server running, and noticed it was saying there are 404 errors when accessing the login page in the API. So I attempted to manually browse to it and also receive a 404 "Not Found" when trying various URLS, for example:
http://{my.server.com}/zm/api/host/getVersion.json (replacing the {my.server.com} with my LAN IP of course)
Going to http://{my.server.com}/zm/api/ gives me the following:
"CakePHP: the rapid development php framework
Not Found
Error: The requested address '/zm/api/' was not found on this server.
CakePHP 2.10.24"
Any ideas? Thanks for your help
