Zoneminder disk size
garbia
Post by garbia »
Hello all, I use vmware fusion, on Ubuntu 18 server, never had any issue but this test installation I did last week, only uses 195gg of this space instead of the whole 1tb available, not sure how to fix it in zm.
See attached snip
What did I do during installation to have it using less space for storage?
Greenshot 2021-06-06 09.14.45.png (61.77 KiB) Viewed 3792 times
Re: Zoneminder disk size
Is it using LVM?
garbia
Post by garbia »
yes looks like it!
check the snip
Greenshot 2021-06-06 21.10.46.png (22.68 KiB) Viewed 3763 times
Greenshot 2021-06-06 21.04.34.png (26.89 KiB) Viewed 3764 times
There you go.
garbia
Post by garbia »
thank you, it was an easy one I will leave the post it may help someone
Seems to be one of the 'joys' of Ubuntu.
