Trouble with all my cameras with 1.36.4 from 1.32
Posted: Thu Jun 10, 2021 12:17 am
So I've been using Zoneminder for a long long time. I have been using 1.32 recently for a couple years without too many issues. I installed a new Ubuntu 20.04 server to try and test out 1.36 (installed 1.36.4) only to find that pretty much all my cameras do not work. (the ones that I don't know I haven't tested yet). Using the same configurations I had in 1.32 don't work at all or give some weird errors I don't know what to do with. For example:
Camera: Amcrest 841b v3 (brand new, works great in 1.32)
Source Type: FFmpeg
Source Path: rtsp://user:pass@camaddress/cam/realmonitor?channel=1&subtype=0
Error in syslog:
Jun 9 19:06:42 janus zmc_m2[15688]: ERR [zmc_m2] [Unable to open input rtsp://user:pass@camaddress/cam/realmonitor?channel=1&subtype=0 due to: Immediate exit requested]
Camera Foscam 9821P v2 (long time works great in 1.32)
Source Type: FFmpeg
Source Path: rtsp://zmuser:zmz0n3r@user:pass@camaddress:80/videoMain
Error in syslog:
Jun 9 19:09:07 janus zmc_m1[15894]: ERR [zmc_m1] [Unable to open input rtsp://user:pass@camaddress:80/videoMain due to: Invalid data found when processing input]
Jun 9 19:11:31 janus zmc_m3[15991]: ERR [zmc_m1] [Failed to prime capture of initial monitor]
Camera: Amcrest 844
Source Type: FFmpeg
Source Path: rtsp://user:pass@camaddress:80/cam/realmonitor?channel=1&subtype=0
Error in syslog:
Jun 9 19:11:31 janus zmc_m3[15991]: ERR [zmc_m3] [Unable to open input rtsp://user:pass@camaddress:80/cam/realmonitor?channel=1&subtype=0 due to: Invalid data found when processing input]
Jun 9 19:11:31 janus zmc_m3[15991]: ERR [zmc_m3] [Failed to prime capture of initial monitor]
Camera: TrendNet IP410 (super old, but has been very reliable)
Source Type: Remote
Host Name: user:pass@camaddress
Port: 80
Path: /cgi/jpg/image.cgi
Error in syslog:
Jun 9 19:14:59 janus zmc_m4[16055]: ERR [zmc_m4] [Unrecognised content type '']
Jun 9 19:14:59 janus zmc_m4[16055]: ERR [zmc_m4] [Unable to get response, disconnecting]
Jun 9 19:14:59 janus zmc_m4[16055]: ERR [zmc_m4] [Failed to capture image from monitor 4 IP410Outdoor (1/1)]
I've tried a fresh system install a couple times, followed all the walkthroughs on setting it up I could find, no success.
So what's the deal? Why am I having such problems with the brand new version of ZoneMinder when it works in 1.32? Why is this progressing backwards?
Source Type: FFmpeg
Error in syslog:
Source Type: FFmpeg
Error in syslog:
Camera: Amcrest 844
Source Type: FFmpeg
Error in syslog:
Source Type: Remote
Port: 80
Error in syslog:
