A Linked monitor will not trigger an upstream monitor after zone changes
lk777
Post by lk777 »
I am experiencing the following issue with the linked monitors.
My setup:
A High Resolution monitor (Nodect): Linked Monitor - Low Resolution (Modect) *(Storage JPEGS, Video writer - disabled).
Everything works until I change/add zones on the Low Resolution monitor. It will not trigger a High Resolution monitor any longer after these changes.
And only zoneminder service restart fixes it.
Re: A Linked monitor will not trigger an upstream monitor after zone changes
What version of ZM? I fixed an issue like this back during 1.35 development, but am fairly confident in the code now.
lk777
Post by lk777 »
Ubuntu 20.04 LXD container (a host 20.04 as well)
ZM 1.36.4
lk777
Post by lk777 »
And one more.
Just do not want to start a new topic:
Ubuntu
/usr/share/zoneminder/www/api
not all files have the right ownership, at least, in my installation they were root:root instead of www-data:www-data
It flooded logs with the cake permissions errors.
lk777
Post by lk777 »
Update:
Now it is v1.36.5
It is not only changing zones (as I initially thought) but even opening/closing zones breaks monitors link.
dangelsaurus
Post by dangelsaurus »
same issue here. linked monitors work fine until you change the motion zone in the lower res monitor... v1.36.5
It has been mentioned on a few threads. Either a ZM restart or a change of the monitor type (then change back) will sort it.
dangelsaurus
thanks Magic, that's reasonable. I'll give that a shot. Still a little new to ZM
