I just realized that after the upgrade to 1.36.X logs cannot be anymore deleted from GUI. Was that intentional or?
Delete logs from interface
- knight-of-ni
Re: Delete logs from interface
If you are trying to delete logs to save space, then do that under Options -> Logs to have them automatically purged.
If you are trying to delete events to simply get them out of the way, then use the search filter instead.
