nginx to confuse with Apache
JRM0316
Post by JRM0316 »
Hi...
How do I install nginx, on Raspberry pi 4, with ZOneMinder 1.36; installed? As I understand it, I can't install it, as it already has Apache installed, and they "get confused".
ergamus
Re: nginx to confuse with Apache
Post by ergamus »
JRM0316 wrote: Sat Jul 03, 2021 4:45 pm Hi...
What distribution are you running on your RPi4? We'd have to figure out if ZM provides Nginx configuration files for your distro, I know this is offered for Fedora in a specific package. For most distros the main setup involves installing a LAMP stack, where you'd probably skip installing Apache and install NGINX instead.
Does the Zoneminder post-install readme mention NGINX at all? This is what's mentioned on my system:
6. Continue on to the next README that corresponds to your chosen webserver:
     README.httpd - Follow these steps when using Apache
     README.nginx - Follow these steps when using Nginx
If you're already running, I'd make a backup of the ZM database before touching anything. Better yet, a full backup of your attached storage (SD card, USB, SSD, etc.).
JRM0316
Post by JRM0316 »
No, I wanted to install nginx, so I could access Zoneminder outside my network.
The linux I use is Ubuntu 21.04. nginx is already installed, but it doesn't work, I'll put a photo to show you where I left off.
What should I do?
swolsen
Post by swolsen »
It looks like you have a problem with the /etc/nginx/sites-enabled/example file.
