I am running the dlandon container for Zoneminder in Unraid.... on or around June 25, Zoneminder was failing to start... Upon reviewing the logs, it looks like I have a corrupt database based on the information that DLandon mentioned in his support forum on unraid. His advice was to ask for help here.
Here is what the logs are showing:
*** Running /etc/my_init.d/40_firstrun.sh...
Using existing conf folder
File zm.conf already copied
Moving zmeventnotification.ini
Moving secrets.ini
Moving the event notification server
Moving the pushover api
Using existing ssmtp folder
Using existing mysql database folder
Copy /config/control/ scripts to /usr/share/perl5/ZoneMinder/Control/
Copy /config/conf/ scripts to /etc/zm/conf.d/
Creating symbolink links
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
*** Running /etc/my_init.d/30_gen_ssl_keys.sh...
using existing keys in "/config/keys"
Moving secrets.ini
Using existing data directory for events
Using existing data directory for images
Using existing data directory for temp
Using existing data directory for cache
no crontab for root
Starting services...
* Starting Apache httpd web server apache2
* Starting MariaDB database server mysqld
...fail!
root@NZWHS01:/mnt/user/appdata/Zoneminder# cd mysql
root@NZWHS01:/mnt/user/appdata/Zoneminder/mysql# ls -al
total 188468
drwxr-xr-x 1 106 108 328 Jul 6 11:16 ./
drwxrwxrwx 1 nobody users 270 Jun 30 12:19 ../
-rw-rw---- 1 106 108 16384 Jun 26 09:08 aria_log.00000001
-rw-rw---- 1 106 108 52 Jun 26 09:08 aria_log_control
-rw-r--r-- 1 106 108 0 Jan 4 2021 debian-10.3.flag
-rw-rw---- 1 106 108 1865 Jun 30 21:33 ib_buffer_pool
-rw-rw---- 1 106 108 50331648 Jul 6 11:16 ib_logfile0
-rw-rw---- 1 106 108 50331648 Jul 6 11:16 ib_logfile1
-rw-rw---- 1 106 108 79691776 Jun 26 23:25 ibdata1
-rw-rw---- 1 106 108 12582912 Jul 6 11:16 ibtmp1
-rw-rw---- 1 106 108 0 Jan 4 2021 multi-master.info
drwx------ 1 106 108 2708 May 20 00:08 mysql/
-rw------- 1 106 108 16 May 20 00:08 mysql_upgrade_info
drwx------ 1 106 108 12 May 20 00:08 performance_schema/
-rw-rw---- 1 106 108 24576 Jul 6 11:16 tc.log
drwx------ 1 106 108 2690 Jun 15 06:16 zm/
