Timestamp Location and Disk Space and Filters
FredZ
Post by FredZ »
Hello all
How can I change the location of the timestamp?
I also want to know how to display total disk space ussage in the banner of the page.
This is bacuase I have a dedicated disk for each camera and I want to quickly see usage at the top of the page for each disk. Currently it shows load/DB/Storage: dev/shm:
Does the PurgeWhenFull filter automaticaly apply itself to all disk drives or do I have to setup a filter for each attached drives/storage locations?
ZM: v1.34.25
Regards
Fred
Andyrh
Re: Timestamp Location and Disk Space and Filters
Post by Andyrh »
The time stamp location is in the same tab on the camera setup window as the time stamp format.
Each storage pool needs a purge filter. This topic should help.
viewtopic.php?f=40&t=30516
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
FredZ
Post by FredZ »
I have attempted to move the timestamp as per the docs. EG, Y=image hieght -8 should place the timestamp at the bottom of the image. But there seems to be no change for me.
The filter was an easy fix, thank you.
Regards
Fred
Andyrh
Post by Andyrh »
I use the camera timestamp because ZM does not write them with passthrough so I will not be much help with that.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
FredZ
Post by FredZ »
I assumed that in the camera setup was the only place to change it. So that is where I have changed it.
I also attempted to change the font to large without any effect.
Regards
Fred
FredZ
Post by FredZ »
So it seems I have been leading myself up the preverdial garden path.
My cameras themselves impose the date/time in the image. On closer inspection ZM is placing the Date/Time where expected, as it is in a black background.
Now to get the disk space used to show in the banner of the page.
Regards
Fred
