unable to upgrade to 1.37.1
Posted: Tue Aug 10, 2021 12:42 pm
Hi everybody
I'm not sure if I messed up my zm installation or if I need to upgrade Ubuntu server version, but I'm getting an error while trying to upgrade to 1.37.1 on my server.
I've been running zm on Ubuntu server 18.04 for at least a year now, no issues so far, I upgraded from 1.35 to 1.37.0 without any problems, but when I try to upgrade from 1.37.0 to 1.37.1 I get an unmet dependencies message, and it seems there are no candidates for the missing components.
This is the output from when I try to upgrade:
sudo apt install zoneminder zoneminder-doc
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
zoneminder : Depends: libswscale5 but it is not installable
Depends: libswresample3 but it is not installable
Depends: libjwt-gnutls0 but it is not installable
E: Unable to correct problems, you have held broken packages.
I tried to install the libraries manually, with the same result, no candidates for any of the libraries.
So I'm not sure if it something I messed up, or if it is time to upgrade to 20.04.
Any help will be appreciated
Regards
Ovargaspcr
Regards
Ovargaspcr
