Clean Debian 10 install
wlsitguy
Post by wlsitguy »
Hello all,
I just loaded a clean debian 10 install and am using the instructions here: https://wiki.zoneminder.com/Debian_10_B ... om_ZM_Repo
When I try to run the "systemctl start zoneminder" command it fails to start.
systemctl status zoneminder.service shows:
root@security:~# systemctl status zoneminder.service
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
   Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Fri 2021-08-20 08:16:16 CDT; 5s ago
  Process: 24076 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=1/FAILURE)
journalctl -xe shows:
A start job for unit zoneminder.service has finished with a failure.
-- The job identifier is 6969 and the job result is failed.
Aug 20 08:20:10 security kernel: [UFW BLOCK] IN=enp3s4f0 OUT= MAC=80:c1:6e:74:d8:d2:c0:ea:e4:e3:86:e2:08:00 SRC=205.185.
Aug 20 08:20:14 security kernel: [UFW BLOCK] IN=enp3s4f0 OUT= MAC=01:00:5e:00:00:01:3c:8c:f8:f2:6f:b0:08:00 SRC=192.168.
Aug 20 08:20:17 security systemd[1]: zoneminder.service: Service RestartSec=10s expired, scheduling restart.
Aug 20 08:20:17 security systemd[1]: zoneminder.service: Scheduled restart job, restart counter is at 29.
-- Subject: Automatic restarting of a unit has been scheduled
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- Automatic restarting of the unit zoneminder.service has been scheduled, as the result for
-- the configured Restart= setting for the unit.
Aug 20 08:20:17 security systemd[1]: Stopped ZoneMinder CCTV recording and surveillance system.
-- Subject: A stop job for unit zoneminder.service has finished
-- A stop job for unit zoneminder.service has finished.
-- The job identifier is 7157 and the job result is done.
Aug 20 08:20:17 security systemd[1]: Starting ZoneMinder CCTV recording and surveillance system...
-- Subject: A start job for unit zoneminder.service has begun execution
-- A start job for unit zoneminder.service has begun execution.
-- The job identifier is 7157.
Aug 20 08:20:17 security zmpkg[24435]: INF [Sanity checking States table...]
Aug 20 08:20:17 security zmpkg[24435]: INF [Command: start]
Aug 20 08:20:17 security su[24443]: (to www-data) root on none
Aug 20 08:20:17 security su[24443]: pam_unix(su:session): session opened for user www-data by (uid=0)
I have UFW enabled, incoming ports are blocked except for SSH for remote access. Outgoing ports are open. I disabled UFW and rebooted and nothing changes when I try to start the ZM service. Any kicks in the right direction would be appreciated.
Re: Clean Debian 10 install
I am have run that procedure several time this week wit no issues. I do not use UFW been but that should have no effect on Zoneminder.
wlsitguy
Post by wlsitguy »
Yes, it's odd, MySQL and Apache2 start up just fine.
I thought about going to Debian 11 or going backwards to ZM 1.34
You might try again with Mariadb. Don't second guess the install procedures in the WIKI. They do work.
lbm
Post by lbm »
Does /var/log/syslog gives anything ?
karimba
Post by karimba »
I Had that on mine, fresh install, kept repeating those same restart scheduled errors.
Turns out you need to install sudo, there's a zm process watcher that tries to check for a running process via sudo.
Installed, reboot, tickety boo now.
Cheers
karimba wrote: Tue Sep 28, 2021 9:16 am I Had that on mine, fresh install, kept repeating those same restart scheduled errors.
Cheers
Interesting...
Installing sudo is something I do on a Debian install automatically. RPI Debian has sudo. Guess I will have to add a step in the WIKI procedure to make sure sudo is installed. A rainy day here in Pa. so the lawn mowing will have to wait for another day. Good to have something to do inside!
lbm
Post by lbm »
Same on 1.34.x.
viewtopic.php?f=40&t=30720&p=122007#p121318
I've later upgraded to Debian11, zm 1.36.x.
sudo should simply just be an dependency (or the way it checks if its running using sudo changed).
