Way to remove image from Console page?
asprinkem90
Post by asprinkem90 »
Is there a way to remove the image from the console page? It looks like it's using the same size and on/off setting as the Event images.
I have a few cameras, and like to see if there are events without needing to scroll. With the image in the console, I have to scroll to see all my cameras.
Thank 192.168.0.1 routerlogin 192.168.l.l
parky
Re: Way to remove image from Console page?
Post by parky »
it's under the 'Web' page in options
geraldbrandt
Post by geraldbrandt »
There's another thread here that covers a code change required to remove the image from the console, and keep it in the events page. I did a quick look for it, but couldn't find it.
SteveGilvarry
Post by SteveGilvarry »
viewtopic.php?f=43&t=30918
Searched for it under your posts Gerald as I remembered you asked about it.
geraldbrandt
Thanks, Steve. I didn't think about searching my own posts. Duh!
