After Ubuntu upgrade from 16.04 то 18.04 & 20.04 i have troubles with connecting to a part of MJPEG monitors by FFMPEG.
From monitor log:
In VM clone of ZM server, saved before upgrade, i have ffmpeg -version, where everything's working fine:zmc_m19[4048090].ERR-zmc.cpp/300 [Failed to capture image from monitor 19 BD4680DRZ-186882901903 (1/1)]
zmc_m19[4048090].ERR-zm_ffmpeg_camera.cpp/219 [Unable to read packet from stream 0: error -1094995529 "Invalid data found when processing input".]
ffmpeg test in console:ffmpeg version 2.8.17-0ubuntu0.1 Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.12) 20160609
configuration: --prefix=/usr --extra-version=0ubuntu0.1 --build-suffix=-ffmpeg - -toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86 _64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresa mple --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable- libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite - -enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme - -enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --en able-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enabl e-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --ena ble-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzv bi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable- libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv
libavutil 54. 31.100 / 54. 31.100
libavcodec 56. 60.100 / 56. 60.100
libavformat 56. 40.101 / 56. 40.101
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 40.101 / 5. 40.101
libavresample 2. 1. 0 / 2. 1. 0
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.101 / 1. 2.101
libpostproc 53. 3.100 / 53. 3.100
In updated 20.04 Ubuntu ffmpeg -version (it was 4.2.4 by default but i made an upgrade to try to resolve this problem... wtih no result ):ffmpeg -i http://user:pass@192.168.16.1:8008
[mjpeg @ 0x90fd60] Changeing bps to 8
Input #0, mjpeg, from 'http://user:pass@192.168.16.1:8008':
Duration: N/A, bitrate: N/A
Stream #0:0: Video: mjpeg, yuvj420p(pc, bt470bg/unknown/unknown), 1280x720 [SAR 1:1 DAR 16:9], 25 tbr, 1200k tbn, 25 tbc
ffmpeg test in console:ffmpeg version 4.4-1ubuntu0~20.04.sav0.1 Copyright (c) 2000-2021 the FFmpeg developers
built with gcc 9 (Ubuntu 9.3.0-17ubuntu1~20.04)
configuration: --prefix=/usr --extra-version='1ubuntu0~20.04.sav0.1' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libdav1d --enable-libzimg --enable-crystalhd --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 70.100 / 56. 70.100
libavcodec 58.134.100 / 58.134.100
libavformat 58. 76.100 / 58. 76.100
libavdevice 58. 13.100 / 58. 13.100
libavfilter 7.110.100 / 7.110.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 9.100 / 5. 9.100
libswresample 3. 9.100 / 3. 9.100
libpostproc 55. 9.100 / 55. 9.100
Don't know how to resolve this...ffmpeg -i http://user:pass@192.168.16.1:8008
[mpjpeg @ 0x56295ab5ee40] Could not find codec parameters for stream 0 (Video: mjpeg, none(bt470bg/unknown/unknown)): unspecified size
Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
Input #0, mpjpeg, from 'http://user:pass@192.168.16.1:8008':
Stream #0:0: Video: mjpeg, none(bt470bg/unknown/unknown), 25 tbr, 25 tbn, 25 tbc
