Released 1.36.6 The Memory Remains
Information and announcements regarding the website and forums in general.
# Changes since 1.36.5
- Fix Archive FTP .zip filename not including monitor name. Fixes #3304
- Correct the size of the Longitude and Latitude fields. Fixes #3311
- Optimise API by optionally not loading the Frames from db table
- Handle the case when the monitor doesn't exist more gracefully and not crash. Fixes #3316
- Fix for export zip crashing due to including non existent files. Fixes #3313
- fix build for bionic due to missing libjwt-gnutls-dev
- fix linked monitors not working after a random period of time
- fix unimplemented viewing fps in live view.
- fix fps display in live view when paused
- Update Dark skin to look better
- fix styling of shutdown button making it invisible
- Support specifying the export filename by passing the export_root
- Turn on export functionality for snapshots
- fix save button on monitorprobe
- zmu may still output results even if it encounters errors, so continue even if we have an error return status from zmu.
- Allow specifying export Structure to get a flat zip
- Fix deleting snapshots
- When locking, use the results to reload the object fields fresh as they may have changed since the object was loaded. Fixes Archived events losing their endtime.
- add export and download functions in snapshot.
- Add defaults for AutoMoveTo and AutoCopyTo so that we don't get false changes when saving filters. Fix redirect after save. Re-null the Id of the filter object after temp execute so that we don't reference a no longer existing filter.
- Change monitor->canView semantics so that a specified monitorId trumps the Monitors:None setting. This is so that the console can be hidden, but the group dropdown still gets populated.
- When the selected layout is not freeform, calculate the ratio of computed size to stream source size to calculate a value for scale. Should reduce cpu use and bandwidth from zms
- Fixed 'Call to undefined function Error()' in control_functions.php
- Only show thumbnail if Function is != None
- add autoplay tag. Fixes #3343
- Don't use AUTH_HASH_IPS when talking to zmu as it doesn't support that at this time.
- Fix PTZ Diagonal cmds. Fixes #3300
- add getMonitorStatuses function to return string values for status numbers
- Fix building SQL for ExistsInFileSystem PostCondition.
- Fix how we turn the rows into Event objects.
- Fix value handling in ExistsInFileSystem post condition.
- Add a 5 second timeout when setting suspending/resuming motion detection.Log errors appropriately
- If we fail to suspend/resume, assume we need to disconnect/reconnect to the mmap
- Fix usage summary in zmu, as there must be a space between -u and dbuser, etc
- documentation and readme updates, fixing dead links
- support for building with gitlab CI
- add support for ubuntu impish
- fixes in quoting default values in perl Monitor and Zone objects.
- Return early if packetqueue is empty instead of getting the lock. Return early in clear() if we are not initialised
- Make failure to resolve http remote monitors non fatal
- Fix errors due to not stopping the dbQueue in zmu. Fix crash when querying v4l devices
- LocalCamera: Add a missing include to fix FreeBSD build Fixes #3330
- fix errors reported during adding monitors due to missing Importance member in Monitor object
- Only suspend/resume motion detection if the monitor is doing motion detection
1.36.6
Full Changelog
Re: Released 1.36.6 The Memory Remains
This ended up being a big one. Lots of fixes.
I suspect there will be at least 1 more release in the 1.36 series, but not too many more. Going for a shorter release cycle so we can bring you the needed features.
With cameras going > 1080p, it has become clear that we cannot continue decoding these high res streams. So we are going to accelerate development and since there is a LOT of work maintaining a stable series, we are likely just not going to do it, but instead move forward faster.
Unless someone would like to step up and take over maintainership of the stable series.
