I use multiple cameras in streamed in zoneminder, 5 exactly, but I don't know why, only one is live at a time, impossible to have the stream streamed of all 5 at the same time.
I think there must be a line to add in one of the .conf files or maybe something else to do that I don't know.
I have 5 POE IP cameras which are connected to a POE switch then connected on the network to a raspberry.
It is the raspberry which makes the server under LAMP, then I installed zoneminder.
In terms of settings, I use the ffmpeg with the path:
rtsp://:@IP_of_camera:554/user=admin_password=admin_channel=1_stream=0.sdp?real_stream
only that works because if I configure on "remote" with the protocol "http" and the IP address I do not have an image.
More over if I type the IP address of the camera in the browser I get a page in Chinese and I have no display.
Do you have an idea ?
thank you in advance for your answers.
Charge: 0.16 storage DB:6/151 Storage: Default: 5%, Stockage: 5% /dev/shm: 9%
Problem with POE camera
Re: Problem with POE camera
Not a website issue.
Post in the forum for the version of ZM you're using.
Based on other recent posts it possibly won't run more than one at a time as you haven't enough resource in a RPi especially if you haven't throttled the cameras output
As mentioned more detail on your setup is required and it might be worth having a read through the https://zoneminder.readthedocs.io/en/latest/faq.html
