Page 1 of 1
Released 1.36.7 The Memory Remains
Posted: Mon Sep 13, 2021 8:14 pm
by iconnor
Changes since 1.36.6
- Add an example fail2ban rule
- Email sending: fix html emails when using ZM_NEW_MAIL_MODULES. Improve debugging reduce Info logging
- fix bug in zms causing failed image loading in zmNinja and anywhere a low maxfps was specified
- Updated italian translation
- add missing calls to update_function_pointers allowing SSE Blend functions to be used. Significant improvement to cpu use when doing motion detection.
1.36.7
Full Changelog
Re: Released 1.36.7 The Memory Remains
Posted: Mon Sep 13, 2021 9:00 pm
by iconnor
A big shoutout to all of our contributors, but a special one to Mike Dussault who discovered that we weren't using our SSE or otherwise optimised blending routines. On a 4K 10fps camera stream this one fix reduces cpu use by 60% when doing motion detection.
Posted: Fri Oct 08, 2021 1:50 pm
by meichthys
Wow, great news on the CPU reduction for motion detection!
Posted: Fri Oct 08, 2021 7:54 pm
by gruiarew
Sorry for my stupid q, but do we need to change some parameters? As I see no improvment on cpu usage after upgrade.
Thanks.
Posted: Sat Oct 09, 2021 1:59 am
by iconnor
No, no paramters changes needed. More noticeable on larger resolution cams. like 1080p up.
Posted: Sat Oct 09, 2021 2:00 am
by iconnor
Unless you have ignored everyone's advice and have chosen 24bit colour on the source tab. In that case we can't do any optimisations at all.
Switch to 32bit.
Posted: Mon Oct 11, 2021 5:34 pm
by gruiarew
It is 32 bit. Also I have 2560 X 1440 resolution.
Posted: Thu Oct 14, 2021 6:36 pm
by Bearded_Beef
I couldn't reply on 1.36.8 thread, but thank you for the updates iconnor. 1.36.7 really cleared up a lot of my RAM/CPU issues and this .8 seems even better. It's nice to be able to get the new interface as well as the ability to have a large low res monitor to draw zones on. I owe you a few cups of coffee!
Posted: Thu Feb 03, 2022 4:04 am
by kold121
Thank You For Useful Information Provide.
