I have set debugging to on and have a snapshot but there's a lot of chatter.
09/27/21 11:32:16.905785 zmc_m10[171244].DB1-zm_packetqueue.cpp/336 [Deleting a packet with stream index:0 image_index:693 with keyframe:0, video frames in queue:422 max: 5, queuesize:9]
09/27/21 11:32:16.905795 zmc_m10[171244].DB4-zm_packet.h/112 [packet 693 unlocked]
09/27/21 11:32:16.905805 zmc_m10[171244].DB4-zm_packet.h/99 [locking packet 694]
09/27/21 11:32:16.905817 zmc_m10[171244].DB4-zm_packet.h/102 [packet 694 locked]
09/27/21 11:32:16.905826 zmc_m10[171244].DB1-zm_packetqueue.cpp/336 [Deleting a packet with stream index:0 image_index:694 with keyframe:0, video frames in queue:422 max: 5, queuesize:8]
09/27/21 11:32:16.905836 zmc_m10[171244].DB4-zm_packet.h/112 [packet 694 unlocked]
09/27/21 11:32:16.905847 zmc_m10[171244].DB4-zm_packet.h/99 [locking packet 695]
09/27/21 11:32:16.905857 zmc_m10[171244].DB4-zm_packet.h/102 [packet 695 locked]
09/27/21 11:32:16.905866 zmc_m10[171244].DB1-zm_packetqueue.cpp/336 [Deleting a packet with stream index:0 image_index:695 with keyframe:0, video frames in queue:422 max: 5, queuesize:7]
09/27/21 11:32:16.905877 zmc_m10[171244].DB4-zm_packet.h/112 [packet 695 unlocked]
09/27/21 11:32:16.905886 zmc_m10[171244].DB4-zm_packet.h/99 [locking packet 696]
09/27/21 11:32:16.905897 zmc_m10[171244].DB4-zm_packet.h/102 [packet 696 locked]
09/27/21 11:32:16.905906 zmc_m10[171244].DB1-zm_packetqueue.cpp/336 [Deleting a packet with stream index:0 image_index:696 with keyframe:0, video frames in queue:422 max: 5, queuesize:6]
09/27/21 11:32:16.905917 zmc_m10[171244].DB4-zm_packet.h/112 [packet 696 unlocked]
09/27/21 11:32:16.905926 zmc_m10[171244].DB4-zm_packet.h/99 [locking packet 697]
09/27/21 11:32:16.905936 zmc_m10[171244].DB4-zm_packet.h/102 [packet 697 locked]
09/27/21 11:32:16.905946 zmc_m10[171244].DB1-zm_packetqueue.cpp/336 [Deleting a packet with stream index:0 image_index:697 with keyframe:0, video frames in queue:422 max: 5, queuesize:5]
09/27/21 11:32:16.905956 zmc_m10[171244].DB4-zm_packet.h/112 [packet 697 unlocked]
09/27/21 11:32:16.905966 zmc_m10[171244].DB4-zm_packet.h/99 [locking packet 698]
09/27/21 11:32:16.905976 zmc_m10[171244].DB4-zm_packet.h/102 [packet 698 locked]
09/27/21 11:32:16.905985 zmc_m10[171244].DB1-zm_packetqueue.cpp/336 [Deleting a packet with stream index:0 image_index:698 with keyframe:0, video frames in queue:422 max: 5, queuesize:4]
09/27/21 11:32:16.905995 zmc_m10[171244].DB4-zm_packet.h/112 [packet 698 unlocked]
09/27/21 11:32:16.906010 zmc_m10[171244].DB4-zm_packet.h/99 [locking packet 699]
09/27/21 11:32:16.906022 zmc_m10[171244].DB4-zm_packet.h/102 [packet 699 locked]
09/27/21 11:32:16.906033 zmc_m10[171244].DB1-zm_packetqueue.cpp/336 [Deleting a packet with stream index:0 image_index:699 with keyframe:0, video frames in queue:422 max: 5, queuesize:3]
09/27/21 11:32:16.906043 zmc_m10[171244].DB4-zm_packet.h/112 [packet 699 unlocked]
09/27/21 11:32:16.906053 zmc_m10[171244].DB4-zm_packet.h/99 [locking packet 700]
09/27/21 11:32:16.906064 zmc_m10[171244].DB4-zm_packet.h/102 [packet 700 locked]
09/27/21 11:32:16.906073 zmc_m10[171244].DB1-zm_packetqueue.cpp/336 [Deleting a packet with stream index:0 image_index:700 with keyframe:1, video frames in queue:422 max: 5, queuesize:2]
09/27/21 11:32:16.906083 zmc_m10[171244].DB4-zm_packet.h/112 [packet 700 unlocked]
09/27/21 11:32:16.906098 zmc_m10[171244].DB4-zm_packet.h/99 [locking packet 701]
09/27/21 11:32:16.906108 zmc_m10[171244].DB4-zm_packet.h/102 [packet 701 locked]
09/27/21 11:32:16.906117 zmc_m10[171244].DB1-zm_packetqueue.cpp/336 [Deleting a packet with stream index:0 image_index:701 with keyframe:0, video frames in queue:422 max: 5, queuesize:1]
09/27/21 11:32:16.906127 zmc_m10[171244].DB4-zm_packet.h/112 [packet 701 unlocked]
09/27/21 11:32:16.906143 zmc_m10[171244].DB1-zm_packetqueue.cpp/348 [Packetqueue is clear, deleting iterators]
09/27/21 11:32:16.906153 zmc_m10[171244].DB1-zm_packetqueue.cpp/363 [Packetqueue is clear, notifying]
09/27/21 11:32:16.906164 zmc_m10[171244].INF-zm_monitor.cpp/3107 [Gate: image_count:702 - Closing event 6076404, shutting down]
09/27/21 11:32:16.906174 zmc_m10[171244].DB1-zm_monitor.cpp/2779 [close event thread is not joinable]
09/27/21 11:32:16.906184 zmc_m10[171244].DB1-zm_monitor.cpp/2781 [Starting thread to close event]
09/27/21 11:32:16.906237 zmc_m10[171244].DB1-zm_monitor.cpp/2783 [Nulling event]
09/27/21 11:32:16.906260 zmc_m10[171472].DB4-zm_event.cpp/230 [Deleting video store]
09/27/21 11:32:16.906307 zmc_m10[171472].DB4-zm_videostore.cpp/636 [Flushing interleaved queues]
09/27/21 11:32:16.906472 zmc_m10[171472].DB8-zm_ffmpeg.cpp/69 [av_interleaved_write_frame FLUSH]
09/27/21 11:32:16.906666 zmc_m10[171472].DB1-zm_videostore.cpp/639 [Writing trailer]
09/27/21 11:32:16.907280 zmc_m10[171472].ERR-zm_videostore.cpp/642 [Error writing trailer Error number 162 occurred]
09/27/21 11:32:16.907305 zmc_m10[171472].DB4-zm_videostore.cpp/650 [Closing]
09/27/21 11:32:16.907317 zmc_m10[171472].DB2-zm_ffmpeg.cpp/69 [Statistics: 0 seeks, 8 writeouts]
09/27/21 11:32:16.907337 zmc_m10[171472].DB3-zm_videostore.cpp/670 [Freeing video_out_ctx]
09/27/21 11:32:16.907350 zmc_m10[171472].DB4-zm_videostore.cpp/724 [free context]
09/27/21 11:32:16.907369 zmc_m10[171472].DB4-zm_swscale.cpp/69 [SWScale object destroyed]
09/27/21 11:32:16.907380 zmc_m10[171472].DB2-zm_event.cpp/242 [start_time: 1632738710. 434244 end_time: 1632738716.417874]
09/27/21 11:32:16.907391 zmc_m10[171472].DB1-zm_event.cpp/451 [Inserting 7 frames]
09/27/21 11:32:16.910263 zmc_m10[171246].DB1-zm_db.cpp/189 [Success running sql query INSERT INTO `Logs` ( `TimeKey`, `Component`, `ServerId`, `Pid`, `Level`, `Code`, `Message`, `File`, `Line` ) VALUES ( 1632738736.907280, 'zmc_m10', 0, 171472, -2, 'ERR', 'Error writing trailer Error number 162 occurred', 'zm_videostore.cpp', 642 )]
09/27/21 11:32:16.913356 zmc_m10[171246].DB1-zm_db.cpp/189 [Success running sql query INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES
( 6076404, 110, 'Alarm', from_unixtime( 1632738716 ), 5.69, 10 ),
( 6076404, 111, 'Alarm', from_unixtime( 1632738716 ), 5.74, 10 ),
( 6076404, 112, 'Alarm', from_unixtime( 1632738716 ), 5.79, 10 ),
( 6076404, 113, 'Alarm', from_unixtime( 1632738716 ), 5.84, 10 ),
( 6076404, 114, 'Alarm', from_unixtime( 1632738716 ), 5.89, 10 ),
( 6076404, 115, 'Alarm', from_unixtime( 1632738716 ), 5.94, 10 ),
( 6076404, 116, 'Alarm', from_unixtime( 1632738716 ), 5.99, 10 )]
09/27/21 11:32:16.937043 zmc_m10[171472].DB2-zm_db.cpp/218 [Success running sql update UPDATE Events SET Name='Event-6076404', EndDateTime = from_unixtime(1632738716), Length = 5.99, Frames = 116, AlarmFrames = 107, TotScore = 785, AvgScore = 7, MaxScore = 10 WHERE Id = 6076404 AND Name='New Event'. Rows modified 1]
09/27/21 11:32:17.005687 zmc_m10[171244].DB8-zm_ffmpeg.cpp/69 [Sending:
TEARDOWN rtsp://10.0.4.4/mpeg4/ RTSP/1.0
CSeq: 6
User-Agent: Lavf58.76.100
Session: 65F436BE
09/27/21 11:32:17.005718 zmc_m10[171244].DB1-zm_ffmpeg_camera.cpp/621 [Received terminate in cb]
09/27/21 11:32:17.089026 zmc_m10[171244].DB1-zm_db.cpp/189 [Success running sql query INSERT INTO Monitor_Status (MonitorId,Status) VALUES (10, 'NotRunning') ON DUPLICATE KEY UPDATE Status='NotRunning']
09/27/21 11:32:17.089058 zmc_m10[171244].DB1-zmc.cpp/381 [terminating]
09/27/21 11:32:17.089170 undef[171244].DB1-zm_logger.cpp/224 [LogOpts: level=DB9 effective=DB9, screen=OFF, database=OFF, logfile=DB9->/var/log/zoneminder/zm_debug.log.171244, syslog=DB9]
09/27/21 11:32:17.089202 undef[171244].DB1-zm_packetqueue.cpp/328 [Clearing packetqueue]
09/27/21 11:32:17.089215 undef[171244].DB1-zm_packetqueue.cpp/348 [Packetqueue is clear, deleting iterators]
09/27/21 11:32:17.089227 undef[171244].DB1-zm_packetqueue.cpp/363 [Packetqueue is clear, notifying]
09/27/21 11:32:17.089277 undef[171244].DB1-zm_packetqueue.cpp/328 [Clearing packetqueue]
09/27/21 11:32:17.089295 undef[171244].DB1-zm_packetqueue.cpp/348 [Packetqueue is clear, deleting iterators]
09/27/21 11:32:17.089305 undef[171244].DB1-zm_packetqueue.cpp/363 [Packetqueue is clear, notifying]
09/27/21 11:32:17.089315 undef[171244].DB4-zm_packetqueue.cpp/70 [Done in destructor]
