I just upgraded from 1.34. There was a Clear Logs button on that version. 1.36 no longer makes it visible.
Where do I find the ability to clear my logs if it is even possible.
Thank you.
Can't Find Clear Logs Button
Re: Can't Find Clear Logs Button
There no longer is one.
The filter box toward the upper right is pretty cool...
I see there are log settings which allow me to set clear the log every X days. As long as that does it's job that's good. Yes the flexibility of the searches are nice. Thank you.
yes you can go with 'n days' of number of logs entries to keep it in manageable levels or alternatively just a number to keep
I have changed the alert levels to 'Warning' now as there are so many things logged under 'Info' that you don't need to see unless you have issues
