Page 1 of 1
Can't Find Clear Logs Button
Posted: Mon Sep 27, 2021 4:58 am
by compumatter
I just upgraded from 1.34. There was a Clear Logs button on that version. 1.36 no longer makes it visible.
Where do I find the ability to clear my logs if it is even possible.
Thank you.
Re: Can't Find Clear Logs Button
Posted: Mon Sep 27, 2021 8:17 pm
by dougmccrary
There no longer is one.
The filter box toward the upper right is pretty cool...
Posted: Mon Sep 27, 2021 8:56 pm
by compumatter
I see there are log settings which allow me to set clear the log every X days. As long as that does it's job that's good. Yes the flexibility of the searches are nice. Thank you.
Posted: Tue Sep 28, 2021 9:18 am
by parky
yes you can go with 'n days' of number of logs entries to keep it in manageable levels or alternatively just a number to keep
I have changed the alert levels to 'Warning' now as there are so many things logged under 'Info' that you don't need to see unless you have issues
