I spent too much time already trying to run it into ZM,
here are the specs : Revotech i6032b-POE-FHW, 2304x1296P, lens 3.6mm
I finally got it to work with the following, both in Zoneminder 1.37.0 and VLC :
rtsp://username:password@IPaddress:8554/profile0
where username is usually admin and password is set (forced) in the CMS.exe program (chinese NVR for this cam).
that is for main stream, for lowered stream, use rtsp://username:password@IPaddress:8554/profile1
Source type: Ffmpeg
method: TCP (not UDP)
32 bit color
resolution: any of them
Hope it helps
Kind regards,
Reeko
